09-09-2021, 01:17 PM | #1 |
How to store a carburetor
I have ordered a replacement block and will be pulling my existing engine in preparation for delivery of the new unit. What is the best way to store the carburetor for a couple of months so it doesn't get fouled or rusty?
Thanks |
09-09-2021, 01:37 PM | #2 |
Re: How to store a carburetor
i don't do anything to a carburetor to store them. Some sit for years or decades. Try to run it dry if you can or empty it before putting it up. A couple months shouldn't be an issue.
09-09-2021, 02:35 PM | #3 |
Drain all of the fuel and put it in a plastic bag. Store it in a climate controlled area. I would also let any remaining fuel evaporate before bagging it.
09-09-2021, 02:53 PM | #4 |
I agree with Rotor. That's what I do.
09-09-2021, 03:36 PM | #5 |
Thanks Rotor. Sounds like a good plan.
09-09-2021, 05:24 PM | #6 |
You will find that a rebuild kit is recommended , after they dry out, etc. to each his own, but I find that the $ item is the PUMP. It will DRY up and that is where the problem comes when trying to reintroduce to service. I’ve found that several drops of sewing machine oil on the pump material AND coat pump well makes all the difference. |
09-09-2021, 05:39 PM | #7 |
Great tip hardtimes. I think the A carb can take a pass but many others will benefit.
09-10-2021, 12:30 AM | #8 |
If you vacuum seal it, it will smell the same when opened as the day it was sealed.
09-10-2021, 05:23 AM | #9 | |
:d:d:d:d:d LOL ! Last edited by Patrick L.; 09-10-2021 at 08:41 AM. |
09-10-2021, 05:38 AM | #10 |
Vaccum seal it,then it's ready when your ready. No critters get into it.
09-10-2021, 06:19 AM | #11 |
Many of us store our vehicles over the winter for 6 months and do nothing other than add fuel stabilizer or Seafoam.
09-10-2021, 08:42 AM | #12 |
09-10-2021, 09:38 AM | #13 |
In aviation there is short term storage and long term storage. Short term doesn't take corrosive affects seriously where as long term does. Light oil was used to fill sealed components to minimize corrosive affects. Par-Al-Ketone or cosmoline are external long term coatings to prevent corrosion. Long term storage is any item that may be stored for more than 60-days where climate control is optional.
LPS-3 is an alternative to cosmoline but all of this stuff is messy and difficult to clean off. Last edited by rotorwrench; 09-10-2021 at 09:44 AM. |
09-10-2021, 09:42 AM | #14 |
I spray mine with wd40 and put them in a cardboard box.
09-10-2021, 09:48 AM | #15 |
WD-40 is a solvent that absorbs moisture. That's where the "water displacer" or WD for short comes in. The problem with WD-40 is that it evaporates rapidly and has no real lubricant quality in its make up. It would be good for very short term storage.
09-10-2021, 09:41 PM | #16 |
The cardboard box helps retard evaporation. I seal it good, with shipping tape.
09-10-2021, 11:47 PM | #17 |
All this to store a carb for a couple of months! LOL
09-11-2021, 03:54 AM | #18 |
I just put mine in a container with a top - like a dry wall pail and submerged it with kerosene. Do not know about very long term but it was good to go after a couple years.
John |
09-11-2021, 05:42 AM | #19 |
Thats a lot of work/time. Don't let my carburetors know all this. They'll have a revolt. I've only got about 30. Most are AVSs.
09-11-2021, 06:46 PM | #20 |
Stromberg fits a coffee can
