06-14-2017, 10:00 AM | #21 |
Re: T5 to torque tube adapter
There are a couple of individuals who have put together detailed T5 information available online. Problem is there are a lot of different variations when it comes to individual approaches. I perfer an open driveshaft with a guickchange rear axle. Coop has a cool setup for a closed driveshaft. I prefer the Ford T5z. So, a lot of this depends on personal teaste and goals.
03-01-2018, 02:45 PM | #22 |
I’m interested in buying the adapter 203-909-2829 Curt
05-16-2020, 07:41 PM | #23 |
Q: is there a open Drive yoke I can bolt to the back of the Jeep T5
So I can run my Quick change I want to use the trans mount shown this is why I ask. thank you |
05-16-2020, 08:32 PM | #24 |
I have no idea on the Jeep T5, Coop may know.
05-16-2020, 09:25 PM | #25 | |
You know, I've been thinking about your query for an hour now. When you say "trans mount", are you referring to the Jeep output housing like the black one in this picture? Whether yes, or no, I believe I would be reluctant to try to run this set-up with an open-drive drive shaft. Even in the case of the original Jeep application, this set-up was not designed to have the output shaft transmitting power UN-SUPPORTED at the rear. You must remember that the rear (output) side of this housing was bolted solidly to a transfer case, with the 23-spline output shaft being supported (guided) laterally by a fixed gear inside the transfer case supported solidly by a fixed bearing. In other words, there was no way for the shaft to be able to wiggle left, right, up or down. The only thing at the rear of this Jeep housing is a seal. In our "Torque Tube" iteration, the seal is given a surface to seal on via the smooth, round outer surface on the spline adapter. As far as the lateral support I speak of, the front end of the Ford drive shaft rides in a bushing at the front end of the torque tube which does not allow any lateral wiggling of the drive shaft. Since this U-Joint only has ONE pivoting point, it acts as a solid support for the rear of the Jeep output shaft. Without THAT support or guide offered by the torque tube bushing, the rearmost 6" or so of the Jeep output shaft is not supported laterally behind the rear main shaft bearing at the rear of the main case. I wouldn't suggest trying to run an un-supported yoke like that. Think about the support bushing you normally see a yoke fitted-through at the rear end of an output shaft housing. That support is there for a reason. That's my story and I'm stickin' to it! The pics below depict the seal at the rear of the housing, and the surface on the spline adapter that rides on the seal, yet does NOT prevent lateral movement. Would love to hear yours' or anyone elses comments on this. DD ………………. |
05-16-2020, 09:57 PM | #26 |
Close, but not quite. A SBC Lakewood scatter shield can be redrilled to fit an 8ba block. Then the Chev T5 bolts up direct. No adaptor. |
10-19-2021, 12:28 PM | #27 |
I would like to purchase an adapter. Thanks,Davey
10-19-2021, 04:27 PM | #28 |
DD, aren't there other original T5 extension housings that could be used to support an output yoke? I'm just babbling here, but I suspect you know what all parts are available.
And, if there is no way to do it with factory parts, I don't see any reason that it couldn't be done with a little 'engineering' and access to a shop mill/lathe. I still think there ought to be a way with factory parts, considering that the majority of T5's (non-Jeep 4x4) have an extension housing with output yoke. DD? |
10-19-2021, 07:37 PM | #29 | |
In our Torque Tube iteration, using the Jeep stuff was the only way to make a T5 that short, which we needed to keep a part of the center crossmember. I have seen an aluminum plate machined to bolt onto the S-10 4X4 rear housing that takes a bearing and a seal. But that Chevy 4X4 housing is about 4" longer than the Jeep housing we used. Below is our Jeep version. Below is the S-10 4X4 rear housing....I believe just a little over four inches longer than the Jeep housing. It is actually longer than the T5 Main Case. DD . . |
10-19-2021, 08:33 PM | #30 |
If I recall reading that the Jeep main shaft is getting to be like hen's teeth. Is that accurate, Coop?
10-19-2021, 11:06 PM | #31 | |
For sure, they ain't growing on trees any more, but they're still out there. Most are not going to be particularly cheap. As far as I've been able to determine, the Jeep T5s are all "NWC" (with those funny grooves), and you have to be careful as I've seen some "supposed to be" Jeep shafts advertised as "WC". Below is an example on eBay right now for a 'real' "NWC" shaft. In fact, I've found three over there on 'The Bay' tonight without even trying hard. And don't forget that we have FordBarn member "CRANIUM" who makes that beautiful 23-spline adapter, and he sometimes has the shafts and extension housings available. DD https://www.ebay.com/itm/30239719277...pid=2148182315 |
12-30-2021, 02:25 PM | #32 |
Do you still make this adapter- aluminum plate and spline adapter? Thanks for letting me know.
12-30-2021, 03:15 PM | #33 | |
01C83 ....As I have said before, neither "Heard" nor myself make any of these parts to supply to the public. There is a guy that goes by the screen name "CRANIUM" here on FordBarn who makes the aluminum adapter plate and the all-important SPLINE ADAPTER, although with some experience, many folks can make the aluminum adapter plate at home like we did. "CRANIUM" has not checked-in here on FordBarn since September, but you can try sending him a PM (once you have 10 or more posts to your credit) in the hope that he checks-in here soon. You can PM him directly via the link BELOW. https://www.fordbarn.com/forum/priva...o=newpm&u=6182 CRANIUM also goes by "KATO KINGS" over on the H.A.M.B. He seems to hang-out over there more frequently than here on the 'Barn, and you may try contacting him over there. DD . . |
12-30-2021, 03:57 PM | #34 |
After due consideration, I would think that installing a modern rear axle, instead of spending all that money to modify the trans. A Spicer 44 from a Jeep grand Cherokee are not very expensive and come with Posi/ I used a triangulated rear suspension and coils for the rear suspension. Bur Chassis engineering makes a conversion. Then you have the BEST of both worlds
12-30-2021, 04:06 PM | #35 | |
12-31-2021, 07:25 AM | #36 |
DD, your probably right, I just can't afford a 8" or9". Actually the 9" is alittle over kill for a flathead as the weight of the rear axle determines ride quality. So,, If you have the bucks go with the 8". I use the spicer44 because it's the only one I can afford. With that said. I've never had a problem with one. What ever rear you use, modifying the trans is not a smart move.
Grampst |
12-31-2021, 11:50 AM | #37 | |
Hey Ron ....I understand the economics aspect of your choice in rear ends....you use what you can manage to afford. Now ...MODIFYING THE TRANS? Whether it is a SMART move or not, it's not for the faint of heart. The reason we modified the T5 was mainly for "space" considerations. There is limited space in just about all old Fords when it comes to thinking about OVERDRIVE-like modifications. And for those of us that have gotten those 'clutch pedal side-steps' and 'smoky burnouts' out of our systems a long time ago, there is still a lot to be said for the inherent geometry found in Henry's buggy sprung banjo rear end and torque tube. You put that rear end together correctly and drive it sensibly, it'll survive a lot of "spirited" driving. Hell, you can even overcome the cracked axle and tapered hub problems that these nostalgic rear ends are known for by adapting The Hot Rod Works' (of Idaho) late Ford axle package. The geometry still works un-altered, and that traditional "Banjo-look" is difficult to beat for us hard-core ol' hot rodders. For those that have taken the time to realize it, the folks that originally designed the T5 basic structure did one hell of a job in making the transmission so susceptible to modifications or tailoring to specific needs by simply swapping factory Borg-Warner parts. If you want a SHORT, medium duty overdrive transmission, with FIVE speeds for those that know what tailored close-ratio gears can do for your driving experience and conditions, there is no other BASE transmission that I know of to start with. Our main premise was to end-up with a SHORT transmission that reasonably met the criteria mentioned above, and Borg-Warner's original T5 easily met those criteria. I continue to use a picture of our "SHORTY" T5 that we created through swapping-around some little-known factory parts that simply bolt together. This is one nicely-ratio'd, five-speed, smooth-shifting, SHORT overdrive transmission. That's WHY we modify a transmission in this case. The MAIN case is 9-1/4" from front face to back. Then, the REAR, Jeep tail housing is exactly 6" front to rear. Then we have a 1/2" thick aluminum plate which completes the adaptation to the STOCK old Ford torque tube pieces....a pretty compact package after modifications. DD |
12-31-2021, 05:28 PM | #38 |
I must say, the workman ship and engineering of this product is beyond exelent. along with a hotrod works reworked stock axle, are things many people like me dream of. I just want the adverage builder to have some options that work quite wel with a fractioon of the cost.
At present most of my time and effort has been the development of a better intake port. Designing the flathead valve bowl eliminator was the hardes part, now manufacturing these parts is the next issue. I'm fortunate in the fact that i have a few friends that have the necessary skills to make tem' I also designed a power file from a sawall to make the laminar flow ports. My health prevents me from spending too many hours in the shop. The idea came to me back in 96 when the SBC came out with the Vortec heads, with smaller valves and more hP. The key to Horsepower is to move the torque curve up inRPM's at presen the best ports stop around 45/4800 rpms. As JWL says you can't improve flow even if you remove the valve. Maybe thats whu 2 cycles rev so well. With all this said, It may not work, but atleast it's something to do. Gramps |
