09-10-2021, 11:19 AM | #1 |
Let’s talk about V8 flathead head gasket
I see I the ole web there’s company’s that make various thickness composite head gaskets .
Anyone have any experience using them ? I see there gasket thickness over .100 Could be away to resurrect some of these mint vintage wall hangers . Let’s here your story !
"I can't cry as long as I know the Lord has risen " |
09-10-2021, 05:29 PM | #2 |
Re: Let’s talk about V8 flathead head gasket
Cometic? They are really expensive
09-10-2021, 06:18 PM | #3 |
Yes big $$$ , I’m just thinking out load . Be nice to use those very cool Org EM heads
09-11-2021, 04:45 PM | #4 |
metal gaskets are the best and most trouble free. Composite crap will stick to the head and block and make a big mess and maybe need a stick of dynamite to get the head off.
09-11-2021, 07:47 PM | #5 |
Composite gaskets are not that much of a problem with proper surface preparation and installation. I used to use various types of "goop" on head gaskets, but now use nothing more than a coating of plain ol' grease. You should use the proper sealant on the studs or bolts, though.
09-12-2021, 04:45 AM | #6 |
Charlie ny |
09-12-2021, 06:20 AM | #7 |
Do you think Best head copper gasket would gain 10 tho over the Standard sandwich head gasket compressed
09-12-2021, 06:45 AM | #8 |
I use steel with copper coat and they work fine and if you wanted to use them over again they would work.
09-12-2021, 04:23 PM | #9 | |
Copper composition gaskets can be reused as well. Simply use silver spray paint on each side
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 09-13-2021 at 01:37 PM. |
