07-28-2021, 03:14 PM | #1 |
1933 car fuel sender repairable?
I've read (some time back, that fuel senders of this generation had points; to repair its function, file(or emery-paper) the points. $325 new. whew!
Firstly, the tank is not under the rumble-seat floor pan for easy access; (the floor pan hole re access to the differential = under-the-rumble seat location. ) Apparently the tank has to be dropped, or remove the bumper and panel. The previous owner installed a new tank; said the sender is 'shot'. Thank you. Pat Malone- |
07-28-2021, 04:00 PM | #2 |
Re: 1933 car fuel sender repairable?
'32-'35 Ford fuel gauges are hydrostatic and there is no electricity involved, just copper-plated tubing from the sender in the tank to the gauge unit that serves as an air line wherein air pressure differentials indicate the level of fuel in the tank. The gauge in the instrument panel is a glass tube with special red liquid contained therein. there's no dial. It would seem that you have a replacement tank with a post-'35 electric sender and some type of compatible gauge.
07-28-2021, 05:12 PM | #3 | |
(they COMPLETELY rebuilt my '68 Mustang am fm w/vintage echo chamber, installed a plug for accessory which when used will play through the radio.) EXCELLENT people, service. They provide an estimate prior to beginning work, ( for your yes or no.) Post service & your payment They return the repaired item. ****** |
07-29-2021, 12:26 AM | #4 |
There is an access cover for the sender; at least there has been on the several '33s I've had or worked on. It is on the driver's side and further to the back than the banjo clearance hole.
07-29-2021, 12:29 AM | #5 |
As Rich added, remove this Cover to access the Fuel Sender Unit in the Tank. |
07-29-2021, 08:41 AM | #6 |
07-30-2021, 02:49 AM | #7 |
This '33 3w - typical - floor pan under the rumble seat w/ differential pan hole(& cover - just fond & bought an orig pan hole cover); the floor pan rear edge is 'fortified', connecting to that is an ascending dished metal panel. There is no access anywhere here to the fuel sender!
Thanks or your info. highbeams/Pat Malone |
07-30-2021, 03:16 AM | #8 | |
When I bought the car, over the phone, The seller & I had numerous discussions; he mentioned items that I never even thought of. He said the fuel gauge is dirty w/o red glycerin-type fluid. The fuel sender doesn't function. There isn't access to the sender from a'top. Apparently the tank has to be dropped. I am physically not obliged to do any 'heavy' work, but on Aug 27, a shop I know and trust is goin' through the entire car. The shop is well-known for this as opposed to a tune-up or a problem recently noticed. The previous owner is apparently, now, one of the Untouchables. He was honest, and has spoken enough about it, I'd say. The car is an unresto'd beaut, inside & out. Rusty headed Mohair tacks. |
07-30-2021, 04:45 AM | #9 |
All Ford pass cars 32-40 had an access opening that had a lid held in place by a screw. Maybe someone sealed it on your car at some time. If the original sender is in place on your tank gaining access will be most difficult.The gas line and air line(to gauge) are rigid and cross over the rear crossmember from the left side of the frame.Dropping the tank down far enough to work on it without bending the lines will be a challenge.Very rarely do these senders go bad.They just need a good cleaning. Here is a pic of a restored gauge I did a few yrs ago.I don't do them any more.
07-30-2021, 01:22 PM | #10 | |
(history=one owner '49-'93, sold at estate. '93- '18 one owner. One other & now I. |
07-30-2021, 01:24 PM | #11 |
Is this a sedan? - thx.
07-30-2021, 02:10 PM | #12 |
I am going out on a limb here, but the access plate/cover was provided to get to the fittings (airline and fuel line ) on the sender. The fittings are several inches away (forward) from the sender unit that goes into the tank. (At least on '32 which uses the same King Seeley setup). Therefore you may not be able to remove the sender assembly even if you have the access hole. There is nothing servicable in the sender since there are no moving parts. A through cleaning and inspection is all that is required. Do yorself a favor and drop the tank, you will be glad you did.
07-30-2021, 02:41 PM | #13 |
The fuel sender can be removed thru the access opening. The opening was designed for that purpose.Here is a link to what a 33-34 sender looks like.
https://www.fordbarn.com/forum/showt...ht=fuel+sender |
07-30-2021, 03:32 PM | #14 |
His earlier comments about the tank being replaced suggest that it has/had an electric sending unit, which in most reproduction tanks well removed from the access opening. In fairness, that's based on the photos/illustrations of those tanks that I have seen; I personally have not used a reproduction tank.
08-01-2021, 04:52 PM | #15 |
I apologize to you, Deuce Lover.
08-02-2021, 12:06 AM | #16 |
No problem.Just reread post #2 and your orig post which says your gauge and sender were modified so all that I said doesn't pertain to you situation. Do you in fact have an orig gas gauge (as I pictured)?
08-02-2021, 07:51 PM | #17 |
Thank you Deuce Lover, once again. I did post that there is no access on a '33 3w. You're hopefully aware. Thanks. highbeams Pat Malone.
08-02-2021, 08:09 PM | #18 |
Yes, I do, w/remnants of what was once red.
Does one remove the dirty gauge, or does one removed the machined-gauges panel . . . Being no access to the fuel sender in a '33 3w, the tank must be dropped, and I have had advice by a sage member to do that and view the sender - if there is one - then determine if in fact it is a '33 sender, if it is functioning . . . . . C&G has new '33 senders for beaucoup bucks, in my opinion; likely affordable to others. Thank you! |
08-02-2021, 08:15 PM | #19 | |
Thank you! highbeams Pat Malone |
08-02-2021, 08:17 PM | #20 | |
