12-11-2013, 01:51 PM | #1 |
Big Truck Brakes?
Does anybody on here know about BIG truck brakes? I am having an issue with an F5 where the wheel cylinders will not release once depressed.
12-11-2013, 02:01 PM | #2 |
Re: Big Truck Brakes?
Possibly the master cyl is not returning all the way or the return hole in there is plugged.
12-11-2013, 02:07 PM | #3 |
I was thinking the same thing. The piston is returning all the way because I can feel it on the end of the pushrod. Maybe the release valve inside is sticking?
12-11-2013, 02:41 PM | #4 |
I had a 45 ton and a half that had the same problem. Truck had vaccum assisted brakes. There was a leak in the tubing leading to this vaccum booster. Once I fixed the leak the brakes would release.
12-11-2013, 03:16 PM | #5 |
That sounds like the military style air brakes, similar to a tractor trailer. This setup has a separate booster that runs on vacuum. Im starting to think it was never assembled properly by the previous mechanic but im not sure.
12-11-2013, 10:59 PM | #6 |
