Old 11-19-2020, 11:44 AM   #21
katy
katy's Avatar
Default Re: Jumping a 6 volt battery
Guess I need to get busy shopping for a 1-3/8 1/2" drive socket.
FWIW, 1-3/8" is the proper size for a Model A, but I've heard that some "crank nuts" are 1-5/16" and the one on my A is 1-1/4".
Not all Model As are created equal.
Old 11-19-2020, 12:08 PM   #22
Y-Blockhead
Y-Blockhead's Avatar
I'm just curious. Are these Ratchet nuts or just a regular ⅝"-18 bolt used to hold the pulley on? (Which I am using because I have a Murray Balancer).
Old 11-19-2020, 12:13 PM   #23
katy
katy's Avatar
Yes.
Old 11-19-2020, 11:49 PM   #24
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If you have a fun projects voltage regulator, they warn not to hook up a different voltage to your system.
Old 11-20-2020, 08:17 PM   #25
Purdy Swoft
Purdy Swoft's Avatar
Good info , Thanks , Chuck !!!
Old 11-21-2020, 10:46 AM   #26
Badpuppy
Not with the engine running. OK to get started, just pull the jumpers right away.
Old 11-21-2020, 11:15 AM   #27
54vicky
54vicky's Avatar
? why would it need boost if running another problem with that statement is the minute it starts it is running is it not?
54vicky is offline   Reply With Quote
Old 11-21-2020, 11:39 AM   #28
katy
katy's Avatar
If you're running any electronics and 6 volt system it would be a good idea to avoid 12 volts for boosting unless the starter is isolated.
Old 11-21-2020, 11:47 AM   #29
antiquepa
antiquepa's Avatar
I jumped my Roadster 6volt, w/12 volt..just don't have any lights on and as soon as it starts...disconect. I connected straight to the battery!! Pos to Pos/ Neg to Neg.
antiquepa is offline   Reply With Quote
Old 11-21-2020, 12:08 PM   #30
jerrytocci
I have used a 12 V jump often.
jerrytocci is offline   Reply With Quote
Old 11-21-2020, 12:47 PM   #31
Gold Digger
I learned my lesson back 50 some years ago. I jumped a 48 ford pickup that was 6 volt from a 56 ford 1 1/2 ton truck that was 12 volts. started 48 and got out to unhook jumpers and I think steam from the battery caps was coming out and the spark ignited the gas. It was at night and all I remember was a loud explosion and battery parts and pieces and acid all over me and everything. Lucky my arm took the bulk of the explosion and not my eyes. I'll never do that again.
Gold Digger is offline   Reply With Quote
Old 11-21-2020, 02:29 PM   #32
LEM
LEM's Avatar
I wonder why the manufactures of portable car jump starters don’t make one for 6 V. At least I have not found one.
File Type: jpg 4280047D-9149-4A10-B4B1-61DB3647969D.jpg (29.9 KB, 8 views)
LEM is offline   Reply With Quote
Old 11-22-2020, 10:40 AM   #33
Badpuppy
Was responding to FunProjects warning - basically: don't use the wrong voltage regulator. It won't hurt a 6V regulator to jump with 12V if the cables are removed before the generator spins up to nominal voltage.
Old 11-22-2020, 10:40 AM   #34
Badpuppy
Insufficient demand.
