Old 12-04-2020, 04:01 PM   #1
Andy
Default Rebuilt fuel pump,Input gear, Second gear,
City: Kerrville
State: Texas
Price: Varies
Flathead fuel pump. Apperently rebuilt by AirTex and never used. No sign of use. Has the Airtex part number on it. Diaphram need replaced because of age. Excellent shape otherwise.--$25
39-48 input shaft. 15 tooth.It is in good shape other than some rust damage on the shaft where it was inside the front bearing retainer and retained water. The splines and pilot shaft have very minor surface rust damage. The bearing cavity, synchro teeth and cone all great. The gear teeth are fine. Everything that was inside the case is undamaged -$25
39-48 second gear. Great shape -$20
Andy is offline   Reply With Quote
Old 12-19-2020, 12:28 PM   #2
Andy
Default Re: Rebuilt fuel pump,Input gear, Second gear,Main caps
Bump
