Old 01-10-2019, 11:31 PM   #1
Fourdy
Fourdy's Avatar
Default Gasket thickness??
Can someone refresh my memory as to the thickness of compressed Fel-pro and Edelbrock copper/composite gaskets?
Thanks -
Fourdy
Fourdy is offline   Reply With Quote
Old 01-11-2019, 09:20 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Gasket thickness??
The last one I measured was .057" for the Fel-pro
Old 01-11-2019, 09:24 AM   #3
GOSFAST
GOSFAST's Avatar
Thanks -
Fourdy
Hi "Fourdy", the compressed thickness on the Fel-Pro's specifically, numbers 1055/1056 (copper, photo below) is .058". This is a "nominal" number, could vary a "thou" or so!
The "relaxed" thickness is .062". I would assume any "composite" gasket would also be in this area? Generally speaking you will lose about .004" when torqued-up!
Thanks, Gary in N.Y.
P.S. Can't help on any Edelbrock gasket dimensions, we don't use that brand here at all.
GOSFAST is offline   Reply With Quote
Old 01-11-2019, 11:32 AM   #4
tubman
tubman's Avatar
I checked some Fel-Pro composite gaskets when I was fitting my Edmunds heads and they were also .058 compressed. When you think about it, they should all be designed to end up with the same compressed thickness.
Old 01-11-2019, 12:53 PM   #5
Fourdy
Fourdy's Avatar
Thanks -
I am assuming my other set of "BEST" would be the same?
Fourdy
