07-16-2023, 03:36 PM | #1 |
Starter Switch Non-Contact
Has happened several times with two different repo switches. Won’t make contact to turn the starter, then will several times then won’t. I’ve cleaned, greased with dielectric and replaced and it still happens. How could align the contacts for more surface area?
07-16-2023, 03:58 PM | #2 |
Re: Starter Switch Non-Contact
This may help you:
Bob Bidonde |
07-16-2023, 04:51 PM | #3 |
I haven't really had any trouble with the repro switches in the last 10 years or so.Couple of things that I have found out though.If you use a firewall insulator your shoe might bottom out before it makes good contact.I stretched out my starter rod,made a world of difference.The biggest thing I found was soft shoes can be a problem.That little pad pushes right up into soft shoe soles.The shoes made for people with foot problems,and issued by the VA are the worst.I have a pair of walking shoes that I have to work hard to push the starter button.Hard soled shoes just need a light push to do the job.
07-16-2023, 07:35 PM | #4 |
Keith, the same is true for aftermarket throttle return springs and soft-soled shoes. After a couple hundred miles, the throttle feels like it's coming through your shoe!
07-17-2023, 08:38 AM | #5 |
I appreciate the feedback!
07-18-2023, 02:57 PM | #6 |
07-18-2023, 06:30 PM | #7 |
Keith -
Have you considered installing an "Upstart" (or similar name) pull rod system? You by-pass pushing the starter rod with your shoe and simply pull up on the knob connected to the Upstart design. That depresses the starter switch and the starter turns over. The rod runs up next to the steering column on the right side. It's not all that noticeable and is easily removed for originality's sake. 'Might just make life easier for you in your Model A! Marshall |
