01-19-2012, 08:35 PM | #1 |
ticking sound
ive got a 30 model a, and im getting a ticking sound coming from the rear passenger side of the engine. i thought at first it was a exhaust leak but i put new manifold gaskets and a new pipe on it. it may be a cracked manifold, i sure hope not. is there anything else yall can think of? is there anyone around sherwood, or little rock arkansas that may could listen in person?
01-19-2012, 09:04 PM | #2 |
Re: ticking sound
Driver's side and exhaust manifold? Do you have a RHD car?
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
01-19-2012, 09:06 PM | #3 |
Re: ticking sound
01-19-2012, 09:16 PM | #4 |
Re: ticking sound
Could it be from the distributor and traveling back?Model A's and noises are hard to detect cuz they all rattle!!!
www.whidbeymodelaclub.com |
01-19-2012, 09:18 PM | #5 |
Re: ticking sound
How about a valve that's too tight?
01-19-2012, 09:22 PM | #6 |
Re: ticking sound
01-19-2012, 09:26 PM | #7 |
Re: ticking sound
Use a cheap stethascope, take the probe off & just use the open hose and you can probably locate it quickly.
01-19-2012, 09:27 PM | #8 |
Re: ticking sound
its gets really loud in the car when im on the gas or speed up, when i let off i cant hear it
01-19-2012, 10:00 PM | #9 |
Re: ticking sound
Could be a hairline crack in the exhaust manifold. With the hood open move the throttle up and down and look/ listen. If it's a crack it will get worse rapidly. look carefully underneath the manifold for cracks.
02-12-2012, 10:12 PM | #10 |
Re: ticking sound
Could still be a blown manifold gasket,even if it was changed recently Those white gaskets that come in the kits are almost useless specially if the rear of the manifold is warped.You need a manifold thats not warped or drooped to seal properly .Use the copper or steel-clad gaskets.
02-13-2012, 01:18 AM | #11 |
Re: ticking sound
Another way to help pinpoint where the tick is coming from is to use a long screw driver. Press the handle to your ear firmly and touch different places on the engine with the blade. STAY AWAY FROM THE SPARK STRAPS! Taking a spark in the ear will really ring your chimes.
