10-24-2013, 06:15 PM | #1 |
Fatmans fron axle modification.
Back a few years ago Fatmans products had a modification where you cut the axle in half to creat an independent fron suspension. I've tried to contact them, but all I get is a recording. Anybody ever have any knowledge of this system??
10-24-2013, 06:34 PM | #2 |
Re: Fatmans fron axle modification.
Here's a little info.
http://www.jalopyjournal.com/forum/s...6962&showall=1 Here's more plus a response from Brent V. http://www.hotrodders.com/forum/fatman-ifs-30653.html |
10-24-2013, 07:08 PM | #3 |
I have had experience with this back in the late 60's, this concept seemed to evolve in auto racing combined with a Flemke spring as a cheap IFS substitute before IFS took over. The problems centered around toe steer and excessive tire scrub as the camber changed. This set up required a center link tie rod pivot if you wanted any suspension travel for a softer ride.
The most effective version was the Ford twin I beam design used on pickup trucks. This placed the pivot of the axle at almost the opposite side of the vehicle so it held camber changes to a minimum amount. To replicate this design you would need to purchase two axles to do the job. If you are just cutting an I beam axle in half and making two pivots at the center of the vehicle it might look cool but its a lot of work to operate correctly. You may get a slightly softer ride and remove some of the washboard feel of a solid I beam but you create a few more issues. Its like anything else yes it does work but if it worked well you would see it on a lot of vehicles, now its a conversation piece.
dickspadaro.com |
10-24-2013, 09:33 PM | #4 |
I think the Allard/Ford cars in the UK had something similar.
10-24-2013, 10:25 PM | #5 |
Well this is very interesting, I guess no one has actually used this except old Alard. Looking at the geometry of a coil over and a long wish bone setup center steering. The unit would have some ride quality. Now that leaves the camber issue???
10-25-2013, 03:04 PM | #6 |
http://en.wikipedia.org/wiki/File:Ba..._ed,_1935).jpg |
10-25-2013, 04:54 PM | #7 |
Thanks, that's very interesting. However the tie rods would have to be the same length ad the axles to prevent bump steer. It would also require center steering, I think?? I'll work on the geometry.
10-25-2013, 05:39 PM | #8 |
Boy Ron: Now you've loosened the cobwebs inside my head as now I too remember those ads. Never saw one actually installed but I think (?) Street Rodder mag did an article on it.
Paul in CT |
10-25-2013, 06:25 PM | #9 |
I think someone did. I don't plan on using the stock spring but a coil over shock.
10-26-2013, 12:47 PM | #10 |
There is going to be a lot of camber change going on.
10-26-2013, 01:35 PM | #11 |
Here's a bit of the Bellamy Ford V8 Special
https://www.youtube.com/watch?v=h-1VXJ5P98U |
10-26-2013, 03:09 PM | #12 |
I talked about it to a fat guy at a show way back when. He said it was show car only stuff and not really for street use. The stock type springs can't carry the load and the steering is very crazy.
10-26-2013, 03:24 PM | #13 |
10-26-2013, 03:38 PM | #14 |
Well I might just give it a go. Can't never tell what you'll learn when someone different tries it. After all, they thought the earth waz flat for a long . long, long time.
10-26-2013, 06:29 PM | #15 |
I'm thinking now that it was for a tube axle only. FWIW
Paul in CT |
10-26-2013, 06:35 PM | #16 |
Check out the Street Rodder tour car. I believe it was 2007, the 75th anniversary of the duce. It had a 2 piece front axel with coil overs. Must have worked o k , Jerry Dixie drove it about 20000 mi that summer. Cant remember which company manufactures the kit.
10-26-2013, 08:09 PM | #17 |
http://www.hotrodders.com/forum/spli...am-169020.html Some discussion on it.
10-26-2013, 09:50 PM | #18 |
Tony, that looks like the Fatman, The one I have a picture of has an "L" shaped steering arm that operates the tie rods.
10-27-2013, 04:20 AM | #19 |
Hi Ron, I race an Allard here in the UK, which is circuit racing, and drive it alot on the road too. The Allards split front axle was most successful with coil springs. The radius arms on my car run forward to a bracket that puts their pivot in line with the pivot of the axle.
I bent an axle in a crash and it cracked badly. So I bought a Ford V8 axle to make one. Its easy. You machine a piece of steel tube roughly 2" for a bush and pin, and put a 2" hole saw through the axle where you want to cut it, to get a nice radius to weld the tube to. The split front axle works surprisingly well, but the short length does mean the camber changes alot as the wheel swings through its full movement. You can control this with stiff springs and shocks. Castor is very well controlled. The work is in making and mounting the centre brackets for the axle pivots, and a whole new sub frame hanging out the front to mount the radius arm pivots. Lastly the boxes on the frame rails to mount the coil springs. Allard based his cars on the V8 chassis so you can just copy what I have for your funky new front end! Cheers, Tom. |
10-27-2013, 04:38 AM | #20 |
You also need to split the track rod to avoid bump steer. This involves an idler mounted at the same place as the split axles.
These may not be clear but show my Allards front end pre restoration. |
