Old 06-23-2018, 10:10 AM   #1
Bruce of MN
Bruce of MN's Avatar
Default Radiator Draining
I wanted to drain the radiator without flowing across the engine pan, so I used a flexible drain funnel and a piece of 2" PVC pipe leading to a drain pan on the floor. The funnel is formed to keep the coolant from overflowing.
Old 06-23-2018, 11:03 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Radiator Draining
You could also just connect a piece of tubing to the drain. It would slip over and be held snug over the boss on the end of the valve.
Old 06-23-2018, 11:59 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The drainage stains will WIPE OFF!
Bill Leturrip
"THE ASSISTANT GURU OF STUFF"
Old 06-23-2018, 08:23 PM   #4
Big hammer
If you would spray a little pam to the pans things wont stick ! OH differant kind of pans :-)
get a bigger hammer tap done
Old 06-24-2018, 04:46 AM   #5
Bruce of MN
I considered using tubing, but the pan seemed to close to get a good grip on the tubing to push it on. But, it works for you, so I'll try it again; 50% fewer pieces!
Old 06-24-2018, 06:34 PM   #6
bambooboy
bambooboy's Avatar
alum foil does the job,then throw away
bambooboy is offline   Reply With Quote
