10-12-2010, 03:08 PM | #1 |
37-48 rear ends and 32 Fords question
Howdy gang..ok, need to pick some brains on this one..if I have late rear, and a 32 V8 torque tube and drive shaft, with the spline adaptor, other than perhaps shorting things to fit will this combo work? Am I totally off, or any suggestions would greatly apprciated. I have seen some simular discussions but am still a bit confused. Thanks!
-Eric |
10-12-2010, 04:07 PM | #2 |
Re: 37-48 rear ends and 32 Fords question
Eric - Do the 32 and later rear ends have the same torque tube bolt pattern? For some reason, I'm under the impression they are at least slightly different. Good luck!
10-12-2010, 04:13 PM | #3 |
If you have a "late" ('33 to '48) rear, the '32 torque tube will NOT fit. The bolt patterns are different. Also, there's a difference in the dimension from the centerline of the axle to the face of the banjo casting where the torque tube attaches. Also, the '32 drive shaft is a very different animal from the later driveshafts in that the pinion mounts directly on the driveshaft (like a model A) and doesn't have a bearing at the very end like the later rears have. I myself don't know if the rear end of the '32 driveshaft can be whacked off and replaced by the spline adapter. Perhaps someone else will chime in. I'll try to add some links to previous discussions.
Don't never get rid of nuthin! |
10-12-2010, 04:32 PM | #4 |
Thanks Pete! I have an opertunity to pick up a complete (although been sitting outside for awhile) 32-34 V8 rear(it has the scalloped flange)..But I do not know which it is. If I measure the torque tube will that tell me? if so what are the measurments. And if its the 33-34 than Im good to go relativly speaking on the parts selection?
Thanks again! -Eric |
10-12-2010, 04:38 PM | #5 |
BTW Im under the impression that the round flange is a 4cyl rear and the scalioped rear is a V8. Is this correct?
10-12-2010, 04:56 PM | #6 |
10-12-2010, 05:07 PM | #7 |
Here are two of the threads I participated in...
http://www.fordbarn.com/forum/showthread.php?t=8439 http://www.fordbarn.com/forum/showthread.php?t=13674 They should help...
10-12-2010, 06:45 PM | #8 | |
10-12-2010, 07:55 PM | #9 |
Excellent info Randy, Thank you I will check out this other rear this week.
Pete, thanks for the forum links, any info I can gather is good! Thanks! -Eric |
10-13-2010, 12:08 PM | #10 | |
Early V8 Garage Pasadena Roadster Club |
10-13-2010, 03:56 PM | #11 | |
