12-02-2013, 03:43 PM | #1 |
Shift Knob Rusted On Shifter
I have a very nice early mushroom style shift knob that is rusted to the shift tower. I have turned it upside down in a vise and have been soaking it often with the acetone, transmission fluid 50 50 mix. I even tried heating the shift tower. I have tried turning it with a band clamp wrench. I am trying to be careful as I do not want to break the knob. Anyone found anything else to work? As a last resort, I could probably cut the tower drill and re tap it.
12-02-2013, 03:59 PM | #2 | |
Re: Shift Knob Rusted On Shifter
Just went thru same situation recently. Soaked the knob repeatedly and let it sit in sunny socal sun. Twisted back/forth , by hand, nothing for long time...then started to move. Soaked then for another month, then just when I was about to use 'bigger hammer' , it gave in/came loose. Beautiful onyx (?) with solid threaded brass base. Figured someone would appreciate it..if I could/would get it off. Ha, set it aside and forgot about it..till you came along,eh ! NEVER GIVE UP !! |
12-02-2013, 04:38 PM | #3 |
About 5 years ago I had the same thing with a mushroom knob. Strap wrench wouldn't budge it, so I sprayed some Gibbs on it and set it aside. A week later I unscrewed it with my hand. I still can't believe it worked so well. Nothing before or after has had such a complete turn around like that. Gibbs and Kroil always help. but it's usually still quite a fight.
12-02-2013, 04:46 PM | #4 | |
12-03-2013, 12:57 PM | #5 |
PB Blast also works well for projects like this.
Don't use WD-40, especially if you live anywhere near either an ocean or where they salt the roads or you will make it worse.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
12-03-2013, 01:05 PM | #6 |
12-03-2013, 01:16 PM | #7 | |
X2 on that one... But I think I would use just a little Sarcasm :-)) So yes please tell us more |
12-03-2013, 01:56 PM | #8 |
Registered User
try soaking wd 40 on some pot metal.like a door cylinder or pop out
it will destroy it i threw out all my wd 40 its for water displacement i know some have good results with it,but after ruining a perfectly good pop out and door cylinder no thanks |
12-03-2013, 04:12 PM | #9 |
If you like your shiftknob, you can keep your shiftknob, but don't let this happen to you.
12-03-2013, 04:49 PM | #10 |
Try the Kroil. The stuff works like magic! Let it soak in for a while and repeat the process if necessary. Might do it for you.
12-03-2013, 04:53 PM | #11 |
How does it destroy it. Dissolve the metal or ???????? Explain, and over what length of time was necessary to cause this??
12-03-2013, 06:06 PM | #12 | |
About 12 years ago I discovered WD-40 makes an excellent remover for price stickers and the goo it leaves behind. It also removes felt tip markers black ink from plastic. I also use it to protect bare metal on modern cars, such as the alternator, tranny, throttle linkage, etc. If I spray these parts about once a year they stay pretty nice looking. Without the spray the road salt mist will do a number on them. |
12-03-2013, 10:28 PM | #13 | |
WD-40 and salty, wet air will actually promote the oxidation of metals of all kinds. I.E. Rust. Sure, it will break parts free for a while, but then a day or so later, you are back where you started from. You won't find any old timers down on docks by the ocean with WD-40 anywhere on their boats. They usually use either 3 in 1, Kroil, or PB Blast specifically for this reason.
12-20-2013, 02:10 PM | #14 |
The knob finally came off without breaking. I soaked (submerged) the entire knob in the acetone transmission fluid mix for about a week. I then locked the knob between two, two by four pieces of wood and tightened the vise just enough so the knob would not slip when I put a vise grips on the shift tower. I rocked it back and forth and it finally started to move. I checked to make sure the knob was not getting soft from the solution, but seemed to be fine. Hope this helps someone else with the same problem.
12-20-2013, 03:07 PM | #15 |
Good job!
Be sure to clean up the threads before you put it back together.
