11-30-2017, 06:49 AM | #1 |
Early Ford Trucks
Hi Guys
As most know, less than a year ago I purchased a 52 F1. It came with a 3 speed on the floor and what, I believe is heavy duty springs option in rear. The steering column has (near top) a nub which I know was for a column shift. I thought, since Mr Ford was rather cheap. He just used the same column for the 3 speed on the floor. However, recently I saw a friends 50 F1, with floor shift and it had no nub. So what's the opinion here, is my 3 speed on floor added after the fact?
Thanks Andy 1952 F1 |
11-30-2017, 06:54 AM | #2 |
Re: Early Ford Trucks
May be the column went bad and was replaced with a 3 on the tree type column.
11-30-2017, 07:15 AM | #3 |
Or, the transmission went bad and the first replacement they found was a floor shift? Or, they could have just wanted a floorshift?
11-30-2017, 07:33 AM | #4 |
Ok thanks, so in summary Ford would not have used this column.
11-30-2017, 08:38 AM | #5 |
The light duty floor shifted 3-speed was dropped in the F-1's in mid-1950 in favor of a column shifted version of the same transmission. Your truck likely started life with a column shifter and the floor shifted unit was swapped in. I believe your column is correct.
11-30-2017, 08:57 AM | #6 |
11-30-2017, 11:00 AM | #7 |
In 52 you could have a HD 3-sp or crashbox 4-sp, both with floor shift, as optional.
'52 F-1, EAB flathead Last edited by Ross F-1; 11-30-2017 at 11:19 AM. |
11-30-2017, 11:25 AM | #8 |
Thanks Ross. I do believe, it’s a hd based on what I’m seeing with rear springs. Is there any for me to confirm the 3 speed on the floor left the factory this way?
11-30-2017, 11:33 AM | #9 |
Look at the hole in the trans tunnel cover; is it a factory-punched hole, or one hack-sawed out? What does the data plate in the glovebox list for Trans?
Just as likely that someone swapped the steering box due to sloppy steering. The HD trans option doesn't come with HD rear springs, in F-1's there was no factory option for helper springs or additional leaves. (edit - there was an option for an additional leaf) How many leaves does yours have?
'52 F-1, EAB flathead Last edited by Ross F-1; 11-30-2017 at 01:41 PM. |
11-30-2017, 12:11 PM | #10 |
Looks like 8, see pic: iPhone sideways
11-30-2017, 12:22 PM | #11 |
I like that bumpstop! Never seen a spring loaded bumpstop before. I wonder how many more New-To-Me things I'll see in this lifetime?
Alan |
11-30-2017, 12:30 PM | #12 |
That’s why I thought heavy duty.
11-30-2017, 01:36 PM | #13 |
Ford actually manufactured an updated version of the light duty 3-speed center shift transmission that had 1C gears in it. I just don't know how many were used in 1951 or even possibly in 1952 but they did make them for a time.
Heavy duty spring was 11-leaf type P/N 21C-5560-C. The standard spring was 10 leaf P/N 21C-5560-B. This would indicate that they were same as springs used in the 1942 thru 47 time frame for half tons. Last edited by rotorwrench; 11-30-2017 at 01:45 PM. |
11-30-2017, 01:41 PM | #14 |
Stock rear springs on an F-1 were 10 leaves (11 was HD option), ironically it appears they eliminated one leaf to add that "helper"? I can only see 9 leaves.
'52 F-1, EAB flathead |
11-30-2017, 01:50 PM | #15 | |
You probably don’t know but you think factory or dealership added? The bracket on the frame looks original What is 1C gear?
Thanks Andy 1952 F1 Last edited by adileo; 11-30-2017 at 02:00 PM. |
11-30-2017, 06:05 PM | #16 |
My first F-1 in the 70's had that style of bumpstop with 11 leaves, I believe HD, will have to check parts book to see if they have an illustration.
11-30-2017, 06:34 PM | #17 |
[QUOTE= What is 1C gear?[/QUOTE]
These were the new diamond shaped gear set that came out in the 1951 model year. 1C-7017 main drive gear, 1A-7113 cluster, 1C-7061-A main shaft, 1A-7102 2nd gear, and 1A-7100-A low/reverse gear. According to all the info I've found, these are not a common set but they are out there. |
11-30-2017, 07:41 PM | #18 | |
Very interesting and be cool if this truck has it.
11-30-2017, 09:36 PM | #19 |
To me,the redesigned as mentioned by rotorwrench, that would be a nice wide ratio for acceleration and shifting. Wonder if Mac would have any of them part #s?
12-01-2017, 12:52 PM | #20 |
Folks actually look for them due to the improved strength factor but they are hard to find. There have been a few threads on this forum before of owners wondering what they come out of since they won't work with the older gears. Mac VanPelt's book lists them so he certainly knows what they are.
