Old 07-01-2022, 09:01 PM   #1
Lawrie
Lawrie's Avatar
Default Ignition advance
Any one have an idea on the total advance when using a 6.2 head.
Lawrie
Lawrie is offline   Reply With Quote
Old 07-01-2022, 09:55 PM   #2
bruceincam
bruceincam's Avatar
Default Re: Ignition advance
Mine seems to like about 30 deg total.
bruceincam is offline   Reply With Quote
Old 07-01-2022, 10:55 PM   #3
Lawrie
Lawrie's Avatar
Ok thanks
Lawrie
Old 07-01-2022, 11:11 PM   #4
Synchro909
Synchro909's Avatar
Lawrie, I'm running a 6:1 head and on advice from the forum, I set maximum advance at 22° which has been pretty good.
As youth departs, we trust wisdom shall suffice.
Old 07-02-2022, 01:54 AM   #5
Lawrie
Lawrie's Avatar
This is on a new engine which we can only run on the engine stand,other wise if it was in a vehicle I could set it easy,
It is one nice engine, new alloy sump and cylinder head,and Burtz block,new Webber carb as well
Lawrie
Old 07-02-2022, 04:32 AM   #6
Bruce of MN
Bruce of MN's Avatar
This thread addresses timing:
https://www.fordbarn.com/forum/showt...+cutting+wheel
Bruce of MN is offline   Reply With Quote
Old 07-02-2022, 07:38 AM   #7
nkaminar
nkaminar's Avatar
The advance depends on a number of factors. The compression ratio is one. Also the turbulence, design of the combustion chamber, and the squish area gap (should be 1/16 inch). An easy way to find the optimum advance is to run the engine at a high idle speed, about 1,000 rpm, and advance the ignition until further advance does not increase the rpm. That is the knee in the advance curve. Of course, in actual driving, the advance will change depending on the conditions, like going up a grade.
Old 07-02-2022, 07:07 PM   #8
Synchro909
Synchro909's Avatar
Lawrie
Is that Charlie's engine? I think he was putting an alloy sump on his Burtz engine.
Old 07-19-2022, 11:55 PM   #9
Lawrie
Lawrie's Avatar
Arnold, yes on the engine.
when is the 22 degs in, what rpm.
Lawrie
Old 07-20-2022, 01:30 AM   #10
Synchro909
Synchro909's Avatar
Lawrie
Lawrie, Mine is a set like you won't see very often. That shouldn't surprise you.
I made an adjustable stop that I screwed to the side of an original A distributor. It has a screw on it like a throttle stop that stops the top plate with no variation. I didn't like the idea of putting a clamp on the steering column quadrant and have all those mushy connections in between there and the dizzy.. Using the Nurex timing scale and with the engine at a fast idle, I set the stop at 22°. Initial timing was by the usual method and checked with the lever all the way up, it read zero degrees.
Around town, I set it at about half way and once on the open road, I pull the lever down and let the stop take care of everything else. Glenda was driving a while ago on the long, flat open stretches of road near Deniliquin. I saw triple figures on the GPS and it was just starting to "sing". I'm not going to meddle with 22°.
Old 07-20-2022, 10:17 AM   #11
SAXBY2
Some posters suggest 22, 25, 28 degrees or other numbers. Somewhere it's noted that each quadrant notch is 4 degrees, and if so, pulling the lever down 5 notches would be 20 degrees advance?
SAXBY2 is offline   Reply With Quote
Old 07-20-2022, 10:36 AM   #12
alexiskai
alexiskai's Avatar
It doesn't really work that way in practice. The quadrants are different shapes on different types of columns, and because there's a linkage, offset, and a 90° rotation between the spark lever and the distributor upper plate, you don't get a 1:1 mapping between small movements on the lever and small movements at the distributor.
Old 07-20-2022, 11:32 AM   #13
Jim Brierley
The important thing is to not let it ping. Compression does require less advance, as does the chamber design and plug location. The dyno shows that the head I make starts losing power above 20* total advance, most 6:1 heads can probably use 26*
Jim Brierley is offline   Reply With Quote
Old 07-21-2022, 02:45 AM   #14
Dodge
Jim,
That sounds like a very efficient combustion chamber. Congrats.
Lawrie,
Most of the aftermarket Brumefield, Snyder type heads like about 26 degrees.
Dodge is offline   Reply With Quote
Old 07-21-2022, 07:35 AM   #15
Bob Bidonde
Bob Bidonde's Avatar
I have a 6:1 head on the Model "B" engine in my Victoria. The ignition timing is set with No.1 @ TDC in the traditional Model "A" way. Running on 87 Octane gas, pinging starts when driving with the lever 2/3 down and accelerating. That's about 26.8 Crankshaft Degrees (13.4 Camshaft Degrees).
I think there is a lot of scatter in timing at the onset of pinging because of engine, gasoline and driving habit variations.
Bob Bidonde
Old 07-21-2022, 08:15 AM   #16
updraught
updraught's Avatar
The octane rating make a fair difference in my book.
We have 91, 95 and 98 generally. I drove a Cortina bought new by my father in law in 78 for a while with the pinto type engine. It would ping on 91. But add a bit of 95 to create a shandy of one third or one quarter of 95 or even less and it was fine.
updraught is offline   Reply With Quote
Thread Tools
Display Modes
