06-30-2022, 10:46 AM | #1 |
Tapping intake for distributor vacuum connection
I currently have one of the early ~1937 aluminum intakes on the 59A in my '40 sedan. I am planning to swap on a later, Canadian CR7 aluminum intake.
The distributer vacuum brake connection currently connects to a threaded hole in the left front of the intake. Just below the third intake bolt on that side. The later intake does not have this threaded hole. Only a single on the back of the carb mounting surface. Can I safely drill and tap the new intake for this connection? I believe it is 3/8-24. |
06-30-2022, 10:52 AM | #2 |
Re: Tapping intake for distributor vacuum connection
You should be able to do that. Just make certain you are drilling at a proper location to get a vacuum. You will probably have to take the intake off unless you have another one to go by.
06-30-2022, 03:18 PM | #3 |
You can't just drill a hole as some suggest. That factory location under that third bolt amounts to more than just a simple, tapped hole. The pictures BELOW should make the geometry of that FACTORY vacuum connection a little more obvious. That specific location also takes the firing order of the engine into account, as those two cylinders fire 360º apart from each other, making for a more-constant vacuum source for that one location. Coop |
06-30-2022, 03:48 PM | #4 |
Why not use the tapping on the back of the manifold?
06-30-2022, 05:36 PM | #5 |
Buy or make a carb spacer with vacuum ports. The original ports on mine are plugged.
07-01-2022, 10:23 AM | #6 |
07-01-2022, 10:37 AM | #7 |
Seems to me I remember reading that Ford's fitting on the vacuum tube was something unique. Don't know if that applied to the thread pitch or the way the fitting seated to make a tight seal. There is no ferrel as you would see with a plumbing compression fitting.
07-01-2022, 10:45 AM | #8 |
Yes, the Ford fitting is unique, and hard to find locally. If one were to go at it "home made" style, I would go to 1/8" pipe stuff that can be had from the hardware store
