03-06-2022, 06:16 AM | #41 | |
Re: Body to Frame Mounts
Below is an ILL of the mounts giving torque values. I do not know the source as Jwahite (1956 SW) included it in one of his earlier posts (2018) describing his ordeal. |
03-06-2022, 11:06 AM | #42 |
[QUOTE=KULTULZ;2110581]If you made that ILL, you are a man of many talents ...
Thanks for the torques specs. Many talents bwaaahahahahaha. |
03-06-2022, 05:37 PM | #43 |
OK ... The ILL posted above is a partial scan from the 1955 WSM (NOV 1954 - Pg. 195) so the torque values will be correct (1956 should be the same as JW has a 1956 WSM). I will try to scan the complete ILL and post it.
04-04-2022, 11:47 AM | #44 |
It is done. Broke the #10 drivers side loose finally. The rest of them went easy. Loosened both sides then removed the drivers side first. Jacked it up and laid on a few 2x4s. Then wire brushed the mounts and installed new pads. Tightened it down to 20 ft pounds and done, I hope.
04-04-2022, 12:55 PM | #45 |
She's going to ride like a CADILLAC ... er ... LINCOLN
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-01-2022, 09:52 PM | #46 |
12-30-2023, 07:39 PM | #47 |
The acetone/ATF combo is the best penetrant I’ve found yet.
