10-02-2022, 07:00 PM | #1 |
1940 Deluxe Convertible Door Alignment
Hi All,
Getting all the little things worked out on my '40. The passenger door fits perfectly and latches solid. The driver's door sticks out at the top rear 3/8". The bottom rear is perfectly aligned with the rear quarter. As you can see from the pictures, the gap between the door and rear quarter is very consistent. If there was a way to pull the top of the rear quarter panel out 3/8", that would solve the problem. But I don't know if that's even possible. Any thoughts on how to correct this? Thanks in advance, Nick |
10-02-2022, 07:09 PM | #2 |
Re: 1940 Deluxe Convertible Door Alignment
Yeah, I do all those adjustments before I paint. I would first measure the distance between the posts at a landmark on each post. Then check that with someone with a convertible. Maybe Kube has this measurement from the open cars he has restored. Before pulling the top of that pillar out I would want to know for sure, it was in too far.
Has there been bodywork or welding on that side of the car, specifically that post? Good luck on that. |
10-02-2022, 07:15 PM | #3 |
I have no history on this car. I can tell you that the striker plate on the driver's side is bent in slightly, as if the door had been slammed rather hard multiple times. In being bent in slightly, that makes the "hook" part move ever so slightly forward which means it doesn't mesh well with the latch in the door (if that makes sense).
Thanks, Nick |
10-02-2022, 10:11 PM | #4 |
Just measured mine. 54 1/2” inside the tops of the post.
10-02-2022, 10:31 PM | #5 |
Wow. Mine is only 53 3/4" !! The door is only off by 3/8" Not sure how tight the tolerances were back when these cars were made. But a 3/4" difference between mine and Ken's is quite a bit. Not sure what to make of it. Still open for suggestions.
Thanks Ken, Nick |
10-02-2022, 10:55 PM | #6 | |
10-03-2022, 07:59 AM | #7 |
I have experienced the widths between the B pillars vary quite a bit. While the original poster's width seems a bit excessive, well, what "bothers" me more, is the fact that the left door fits properly.
That scares me. For the owner's sake, I pray the right door was fit properly to the body prior to paint. How does the door fit at the A pillar? I would suggest removing all rubber bumpers, including the weatherstrip and the male latch. Then, with nothing that may cause interference, attempt to close the door to the body. Does it (the door) now fit better?
10-03-2022, 08:18 AM | #8 |
Kube, it's the right, passenger door, that fits properly. The driver's door also fits well at the A pillar. The door itself is very rigid and there is no slop in the two hinges. There is no weather stripping on either door. Just the rubber bumper on the lower B pillars and the rubber bumpers above and below the latch. I can post additional pics if that would help. I have the bumpers on order.
Also, just received your book: Ford for 40. A great work!! Nick |
10-03-2022, 08:28 AM | #9 |
One more question: is there a backing plate behind the male latch or is the B pillar tapped for the screws. Don't want to lose a backing plate if it's going to fall when I take the latch out. I also have a new one of those coming too.
Nick |
10-03-2022, 09:14 AM | #10 |
To me, this looks like a body to frame shimming issue, not ruling out underlying frame or body problems.
My experience (with roadsters, in general) is that you have 8 CRITICAL body to frame bolt and shim locations. Front and rear on each side of the cowl, B post and rear on quarter. Each shim affects three axis, front to back, side to side, and front to opposite rear. The corollary to this is that ONE problem is usually at least 3 shims from a solution. Kube has posted some excellent notes on aligning a convertible before... search them out on this forum. A convertible critical issue is that rubber pads are not used as on the closed cars. They are simply to flexible and will not hold the body in the rigid alignment it needs. Ford used steel pads with a thin rubberized fabric pad. Also consider reviewing our body and fender installation guide, a lot of basic, generic, and critical information http://www.wescottsauto.com/WebCatal..._Technical.pdf. There will be no easy fix on this car. |
10-03-2022, 11:25 AM | #11 |
I measured 54 1/4" on my forty.
Glenn |
10-03-2022, 01:36 PM | #12 |
Thanks Karl. Not happy to hear that there won't be an easy fix, but not surprised.
Glenn, thanks for the additional data point. Mine is still quite a bit narrower than the other two. I can live with the mis-alignment, but it would certainly bug me every time I see it. Any other thoughts would be greatly appreciated. Nick |
10-03-2022, 02:41 PM | #13 | |
10-03-2022, 02:56 PM | #14 |
“Go from the bottom of the left post to the top of the right post then do the same for the other side .“
I think that would be a good check. It would be a large dimension so a help in comparing the two. You also have great reference points this way. I had to change the body to frame shim plate, I think reducing it. Took a while with PB Blaster and pry bars. I like to use roofing bars a lot. As Kube said, remove everything that could be affecting the door position. Glenn Last edited by glennpm; 10-03-2022 at 03:18 PM. Reason: Hard to do on cell phone |
10-03-2022, 03:10 PM | #15 |
From the passenger B pillar base to the top of the driver B pillar is 59 3/4". From the base of the driver pillar to the top of the passenger pillar is 60 1/4". This would indicate that the driver B pillar is tilted inwards about the right amount to cause the door mis-alignment. I have several of the early ford books, but none have an exploded view of what Ken is referring to. I'd like to get an idea of what's involved before I start ripping things apart. Is there any documentation that shows this?
Thanks guys, Nick |
10-03-2022, 04:36 PM | #16 | |
10-03-2022, 07:09 PM | #17 |
When I worked for Pierce Ford in Lowell, MA in 1966, a new Mustang convertible had a driver's side door out of alignment as yours is. The service manager put a block of wood between the bottom of the door and rocker panel. He pushed hard on the top of the door a few times and was able to twist the door into alignment. Just saying.
10-03-2022, 07:24 PM | #18 | |
10-03-2022, 08:34 PM | #19 |
That's true, Ken, several things have to be looked at including the B pillar alignment. I know on 35 and 36 convertibles there aren't many ways to adjust the doors. Add or remove shims from the bolts that hold the A and B pillars to the frame. I think in this case maybe move the post a bit twist the door a bit and check for the correct alignment with the top and door glass. If the frame is straight I think, with some patience, this is a fairly easy fix.
10-03-2022, 08:42 PM | #20 |
Thanks everyone. I'm starting to feel a little better about this. Are you thinking adding a shim to the brackets to move the top of the driver B pillar out might do the trick? I'll pull the back seat out tomorrow to see what that exposes. Or maybe it's all visible from below? I need to put it on jack stands tomorrow anyway to change the drag link.
Might sleep better tonight!! Thanks, Nick |
