07-16-2017, 11:51 PM | #1 |
Silicone Dot 5 Brake Fluid
I figured that it was time to rebuild the master and wheel cylinders for my 1941 Ford. The last time I could remember doing it was sometime around 1990. After 27 years of use I was very surprised to find that all the cylinders rubbers looked like the day I installed them, there was no pitting or rust inside any of the components. This is not meant to be a sales add for brake fluid, but it sure made a believer out of me.
Just thought I'd share my results. Sent from my iPad using Tapatalk |
07-17-2017, 01:49 AM | #2 | |
Re: Silicone Dot 5 Brake Fluid
That is exactly why I installed dot 5 in my recent conversion from mechanicals to Lincoln hydraulics. Research and help / ideas from guys here convinced me that silicone fluid is 'non-hydroscopic' (?). If no water gets in, no rust should form. Your 27 year experience is pretty good proof that that is the case ! Last edited by hardtimes; 07-17-2017 at 05:34 PM. Reason: non added for accuracy/posterity ! |
07-17-2017, 04:43 AM | #3 |
Been using it for years. It works for me.
07-17-2017, 04:55 AM | #4 |
I use DOT 5 in all my cars
07-17-2017, 07:27 AM | #5 |
I have used silicone fluid in all my cars for the last thirty years and never a single problem.
07-17-2017, 07:27 AM | #6 |
07-17-2017, 07:55 AM | #7 |
Anybody know the best method for "flushing" all the Dot 3 fluid out of an existing brake system before using Dot 5?
07-17-2017, 08:27 AM | #8 |
I doubt that you will ever get all the Dot 3 out of your system. You can flush the lines, but getting all of it out of used cylinders and master cylinder may be a futile effort. Make the change when you are ready to rebuild or replace all the cylinders.
07-17-2017, 10:17 AM | #9 |
I filled the master cylinder with DOT 5 and then bled the system until it flushed out. No problems. Many moons since.
07-17-2017, 11:18 AM | #10 |
I replaced the master cylinder, wheel cylinders, and rubber lines. But before I installed all the new parts I flushed the hard lines with acetone than alcohol.
07-17-2017, 01:32 PM | #11 |
Dot 5 the correct term is non-hydroscopic
IE Definition of: non-hygroscopic (non·hī′grə·skop′ik) adjective Having little or no tendency to absorb moisture: a non–hygroscopic gunpowder.
07-17-2017, 05:32 PM | #12 | |
Sounds work intensive and maybe work. So, let us know if that works ! Hm, how will you know...no eventual rust in system in years to come ? Hey Frank, That's why the (?) mark added next to hydroscopic. Thanks for the 'assist' |
07-17-2017, 06:21 PM | #13 | |
That's funny Are you correcting youself?
