07-28-2020, 12:09 PM | #1 |
U-Joint Lub
Is there a better way of lubing the throw-out bearing? My PicUp and I are getting older now days, and I'm having a hard time getting to it. Did install a transmission dip-stick which took care of that issue
Thanks |
07-28-2020, 12:39 PM | #2 |
Re: U-Joint Lub
U-joint or throw out bearing?
07-28-2020, 01:49 PM | #3 |
Re: U-Joint Lub
07-28-2020, 01:56 PM | #4 |
Re: U-Joint Lub
Most throw out bearings these days are sealed. How old is yours?
07-28-2020, 02:22 PM | #5 |
Re: U-Joint Lub
Most replacement release bearings today are sealed and can't be greased thru the collar fitting.
Older bearings can be greased thru the collar fitting. A flexible hose could be fitted to the grease fitting to the side of the bell housing so the grease fitting could be accessed near the pedal shaft. |
07-28-2020, 04:12 PM | #6 |
Re: U-Joint Lub
Sealed Bearing -- so that's what my problem is Thank you |
07-28-2020, 04:17 PM | #7 |
Re: U-Joint Lub
That collar needs/should be greased every once in awhile, a pump or two will do.
