09-30-2023, 09:13 AM | #21 |
Re: 2 speed fordomatic
Simple fix ... Put two cans of whale oil in and call me in the morning ...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
09-30-2023, 09:34 AM | #22 |
My 57 Fordomatic has had those same symptoms from time to time. I have used Sea Foam Trans Tune (comes in a 16 oz bottle) with very good results (instructions on the bottle state that it helps free up sticking control valve spools). I would give it about 8 oz for a trial and dump in the remainder if no improvement.
Good Luck, Dave |
09-30-2023, 10:05 AM | #23 | |
Is it just a delayed 2nd gear shift or does it fall out of gear? https://www.jalopyjournal.com/forum/...shift.1260539/ Do you know exactly what the trans came out of (TAG ID NO) and how long it sat? Is your linkage(s) adjusted correctly (no modulator valve)? How gnarly was the drained fluid? Band adjustments?
09-30-2023, 10:17 AM | #24 | |
