05-20-2022, 10:44 AM | #1 |
crankshaft grinder
Looking for a recommendation for crank grinder in Northern Ca capable of putting a 1/8 stroke on a Merc crank. I'm near Chico.
05-20-2022, 12:00 PM | #2 |
Re: crankshaft grinder
If yiu can't find a local source then look no further than Henry Velasco at Velasco Crankshaft Service in Downey CA. 213-877-4212. There is none better than Henry.
05-20-2022, 12:55 PM | #3 | |
Hope you're not in a hurry. Last I knew most of the crank grinders in SoCal are all pretty booked up. But I don't have specific knowledge about Velasco. Hope I'm wrong if you go that route.
Making the simple complicated for over 30 years. |
05-21-2022, 03:01 PM | #4 |
I used Baily Brothers, in Vallejo, Ca.
About twenty years ago. Did not do a stroker, though. Karl |
05-21-2022, 08:11 PM | #5 |
I did a simple quick search (crank grinder shop in Northern Calif.) and came up with at least 30 shops. The problem might be explaining to them what a flathead Merc is....
05-22-2022, 02:26 AM | #6 |
Tell him, Frank in Southern Oregon, sent you. L & M Grinding 1301 E Cypress Ave Redding, CA 96002 Contact: Mario Frugugliette Title: Owner Phone: (530) 221-7652
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
