12-21-2023, 05:44 AM | #1 |
1936 grill lower air scoop picture.
i'm looking for a picture of this sheet metal air scoop that bolts up to the bottom of the radiator on one end, and the lower grill on the other. my project didn't have one and i've never seen one. is it something i can make? any photos would help, thanks.
12-21-2023, 10:15 AM | #2 |
Re: 1936 grill lower air scoop picture.
If you have the1935-36 Ford book, there is a picture of it on p70. It is part #68-16554.
I have been told this was often not put back on by mechanics because it was such a pain in the butt to get back on after they completed work. If you have to work on the ditributer or other parts in that area, this has to be taken off. It is called a radiator shield, used to direct air towards the radiator. I bought one and can attest that it was a real pain to get it on. Maybe it was not made quite to specs because the holes just wouldn't line up no matter what I did. terry |
12-21-2023, 10:43 AM | #3 |
Here from the Bible
Check with Southside Obsolete in MN.Fred might have one. Last edited by deuce lover; 12-21-2023 at 10:50 AM. |
12-21-2023, 11:07 AM | #4 |
i don't have that book. i would like to have though if i could find one. maybe some one here can take a pic of that page. but it sounds like i could wait and come up with something myself. i have a drawing saved that has picture, but it's not much. i'll see if i can find it.
12-21-2023, 11:22 AM | #5 |
The referenced book is available via the Early Ford V8 Club website (earlyfordv8.org) for $29.95; it's areal bargain.
12-21-2023, 11:51 AM | #6 |
Tim Carlig |
12-21-2023, 04:26 PM | #7 |
Tim, are you talking about an origina scoop or one that may have come from China?
12-21-2023, 05:07 PM | #8 |
1936 Ford lower grille support. ford nut is this the part that you are looking for a picture of? |
12-21-2023, 05:52 PM | #9 |
no, i have that one. thanks. it's #16554 from the drawing.
12-21-2023, 05:53 PM | #10 |
12-21-2023, 09:10 PM | #11 |
If you can find an original lower air scoop, it will have the horizontal grooves raised across the scoop. Early reproduction parts had these grooves recessed rather than raised. Only a subtle difference, however I believe they made it that way to avoid copywrite costs that Ford requires to allow you to represent the part as the same as from Ford. Bob Drake has to pay these costs when they represent the part as the same as Ford original and show the Ford oval trademark.
12-21-2023, 09:16 PM | #12 |
Radiator & Grille Assembly for 1936 Ford Passenger Car |
12-21-2023, 09:48 PM | #13 |
gary, thanks for the info.
mercman, thanks for the enlargement. i'm going to call "the early store" here in so-cal and see what they might have. i still would like to make it though. . .i just need to see one. |
12-22-2023, 12:01 AM | #14 |
12-22-2023, 12:21 AM | #15 |
hey thanks! just what i was looking for! pretty nutty price, but there it is. doesn't look like the illustration too much, this really helps me. thank you Randy in ca.
12-22-2023, 11:31 AM | #16 |
Terry, I’m talking original.
Tim Carlig |
12-22-2023, 12:20 PM | #17 |
12-22-2023, 01:13 PM | #18 |
If you want to make your own, consider the required function as more important than what it looks like. It’s not there for looks, without it you’re likely to overheat.
Alan |
12-22-2023, 01:34 PM | #19 |
The odd thing for me was that i went quite a few years without having the part on and as long as I wasn't standing and waiting in a long line my 36 wouldn't overheat. Is there someone that still makes a circular fan shroud for the older v8s to remedy this situation?
12-22-2023, 09:23 PM | #20 |
