05-24-2020, 03:06 PM | #1 |
Would You Use it?
The photo below shows a block with two head gaskets in place, one on top of the other. The top one matches the block with the trapezoidal holes. I don't have those, but I do have the round hole gaskets that match the heads. Will I have any potential water leaks if I go ahead with the gaskets I have, the round hole ones. Would you use the round hole ones without worry,
I know, I'm cheap, but why spend $50 if the ones i have will be fine? |
05-24-2020, 03:41 PM | #2 |
Re: Would You Use it?
There’s another thread on here currently about having coolant leaking on a $9000 motor......for $50 bucks....I’d get the right gaskets....Mark
05-24-2020, 04:06 PM | #3 |
Not worth the gamble. Do the right thing, and the right thing happens.
Enjoy yer day. Tom Hate can't fix what it started. |
05-24-2020, 04:15 PM | #4 |
I'm a cheapskate myself, but after thinking about it; these guys are right!
05-24-2020, 04:22 PM | #5 |
Sell the "wrong" gaskets and that will help pay for the correct ones.
05-24-2020, 04:29 PM | #6 | |
Just something to research: Could the round hole gasket be better because it will force more coolant to the back of the block for better cooling? |
05-24-2020, 04:38 PM | #7 |
Wouldn’t the edging on the holes need to be sandwiched between surfaces in order to seal properly?
Al |
05-24-2020, 04:41 PM | #8 |
You ideally want the part of the gasket with the metal folded over sealing area making contact with metal on both deck face and head face. If the folded over metal part is overlapping a hole you are not making a proper seal and will be risking a leak in that area.
For what it costs you might as well just buy the correct gaskets. |
05-24-2020, 05:18 PM | #9 |
I think that the verdict is in.
With the new parts in it, that engine looks nice and clean. It's not worth the risk. Get the correct head gaskets. |
05-24-2020, 11:22 PM | #10 |
I'd have to look at the rest of the gasket water holes , But I think the round hole gasket is a better gasket than the original f Ford gasket. The parts of an engine go throu an evaluation over time and the industry comer up with little improvement. Like controling the water flow thru the block for better cooling.
I could be wrong here because I very rarely work on stock engines. |
05-25-2020, 12:16 AM | #11 |
When mixing and matching...using older heads on new block we use the gasket that match the heads...not the block...just my 2c.
05-25-2020, 07:03 AM | #12 |
There were two different replacement gaskets available from Ford.
The holes in the heads determined which to use. #6051 for small holes in heads. #6051-A for large holes. If small holes in the heads, use the one with small holes. Also less areas that are susceptible to blowout.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 05-25-2020 at 10:07 AM. |
05-25-2020, 09:42 AM | #13 |
Do any modern gasket manufacturers make a set of quality head gaskets with the trapazoid style water holes? I don't believe I've seen any?
If it was mine, I'd run Best Gaskets Graphtite composite head gaskets and maybe put a bit of copper-coat type sealer on the block surface/side of the gasket. All you're trying to do is seal the water - not compression in this area and I don't believe you'd have an issue. So there yah have it . . . yet another man's opinion! |
05-25-2020, 02:31 PM | #14 |
05-25-2020, 07:42 PM | #15 | |
But, just to make us all think a bit (on the need for gaskets to match the center water jackets) . . . lets talk about three different block water jacket configurations (39 - 48): 1) 39-42 Ford 221: It has three trapezoidal water jackets (the one you show). 2) A 99A or 239 style Merc block has TWO trapezoidal water jackets - with a circular one in the middle. This is the block referred to as the 'Keystone' Merc block that is part of Flathead rumors and lore . . . 3) A 59x series block has one trapezoidal water jacket - up at the top. Best gasket makes ONE style of gaskets for ALL of the above - whether copper or composite. Given that I've had nothing but good experiences with their gaskets (in all three of the above water jacket configurations) and I've heard nothing but positive reviews of their gaskets, one would think there is no need to have a different version for the different water jacket styles in the middle of the block. I use the GraphTite gaskets on just about all of my builds - except high-end blown motors (they're a whole different beast). See below: 1) 99A - 239 Merc - WWII Production: DeckComplete copy.jpg 2) 59x Deck Surface: BlockDesk-Porting-80.jpg 3) Best Gaskets: Copper: BG-Copper.jpg 4) Best Gaskets: GraphTite: BG-GraphTite.jpg 5) And here is a Cometic MLS Gaskets (which I'm running on the 42 Merc block shown above): Cometic.jpg |
05-25-2020, 01:30 PM | #16 |
Doesn't apply here but the early pump in head head gaskets did indeed have larger holes in back and smaller holes in front . The intent was to get equal water flow to the front and back areas of the head . Cannot find pics right now but this is in the books .
05-25-2020, 07:51 PM | #17 |
Here's something to thinking about with those gaskets with the small round holes. A wise and respected engine builder told me this. Why would you want to restrict the water from leaving the block?
The water surrounding the cylinders is acting like a heat sink and trying to carry heat away from these areas. If you keep it in there or restrict it's flow, the water is only getting hotter. This engine builder opens those holes to match the holes in the block to allow the water to get out of the block, into the heads, and up into the radiator to be cooled. Just something to think about. ** To answer the original question, get the proper gaskets. |
05-26-2020, 01:09 PM | #18 |
No idea who the builder is, but couldn't disagree more. Why do you think they make the holes the size they do? Read flatheadmurre post, they are designed that way for a reason! If you look at the total area of all the water passages in the head you can see the volume of fluid they can handle. Making larger holes is just like short circuiting wiring. Yes, the original center holes were larger (the large holes are there mainly to help clean out of casting core, not for cooling), but later designs in head gaskets attempted to correct the overheating issues of the rear cylinders. Take a look at the head, what good is a larger gasket to match the block going to do? Also, see the corrosion where the older style gasket was used? By reducing the size of these center holes even further in later models, it is forcing more of the flow to the rear cylinders. You don't want the majority of the flow to go from the pumps straight through the center of the block and back to the radiator.
05-26-2020, 01:18 PM | #19 | |
I would also not assume that the gasket companies are looking to constantly improve their stuff. There could be many reasons why they changed it |
05-25-2020, 08:10 PM | #20 |
Hey Tim: Something to think about is not only flow, but where does the flow actually go to pull the heat out of the block.
In the 49-53 block design they deliberately put the LARGER water jacket holes at the rear of the block. From what I gather and in thinking about it, this was do give the water a better chance of flowing to the BACK of the block to pull some of the extra heat out of the rear cylinders (which tend to run hot). So - one could also ponder how much water do we want to let out of the middle of the water jackets - versus maybe a better distribution to the rear of the block (in the 39-48 blocks). Is letting too much of it out "early" a good thing or not? (Don't know). Obviously I have not done any scientific testing (with various deck/gasket combinations), but I do believe it is a good thing to try to get the cooler water from the front of the engine to the rear. In some big HP race engines, they put water manifolds down at the base of the block (above the pan rails) to deliberately direct water flow to the back of the block. Another method was to put a sort of "water tube" inside the block that was fed up by the water pump - to have a special flow to the rear of the block. So - letting too much of the cool water out the middle of the block MAY actually NOT be a good thing (again, never tested by me and probably nobody else alive that I know - other than maybe Pete!). I am more inclined to expand the water holes at the rear of a 39-48 block - to try to get more water flow from the back of the block . . . |
