Old 11-11-2012, 07:58 PM   #1
Don S
Default Float a motor question
I have trouble lining up my starter push rod to switch. It needs to be higher than where the grommet is. I was looking at the rubber pucks that go in the float-a-motor mounts. The last ones I put in are 1" thick,the old original ( 20 years ago ) pucks are only 3/4" thick. That means my engine is at least 1/4" too high at the rear. Any body else found this a problem.This could also be hard on the driveline. A good case for original mounts?
Don S is offline   Reply With Quote
Old 11-11-2012, 08:57 PM   #2
Ice man
Ice man's Avatar
Default Re: Float a motor question
If you take a good look at the way Henry designed the originals, they were almost like a cross brace for the frame. The ends at the frame were mounted in rubber, but the other end mounted to the engine and was very stiff. A lot of (improvements) we make are not really all the much of a great improvment.
Ice man is offline   Reply With Quote
Old 11-11-2012, 10:11 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I'm not really sure, but I think there was a top & a bottom, regarding one of the Float-A-Motor brackets?????? Mine on my '30 lined up O.K. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 11-11-2012, 10:18 PM   #4
Don S
I checked the bottom rubber pucks,they are 1" thick. They would be supporting the engine 1/4" higher causing misalignment of the starter rod?
Old 11-11-2012, 10:29 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Sounds like it might mess up the choke rod also.
Old 11-12-2012, 07:36 PM   #6
Don S
I removed the lower rubber pads and cut them down to 5/8" thick. My starter pushrod fits like it should as well as the choke rod. Still lots of clearance on the mounts, no chance of metal rubbing.Thanks
Old 11-12-2012, 07:42 PM   #7
Mitch//pa
there is a top and bottom on the rear mounts and will cause the crank hole not to align properly
Old 11-12-2012, 09:11 PM   #8
700rpm
700rpm's Avatar
Don, please let us know if cutting down the thickness of the pads adversely affects the vibration factor.
Ray Horton, Portland, OR
Old 11-14-2012, 06:24 PM   #9
Don S
Thanks for your interest,but it may be spring before I know,but I will post an answer then.
Old 11-14-2012, 10:45 PM   #10
BILL WILLIAMSON
Get down! Dog,
Buster T. Brown just reminded me NOT to get into the FAM mount thing AGAIN!----------------------Bill W.
Old 11-15-2012, 06:11 PM   #11
Bruce,Upstate NY
Sounds like the cast aluminum brackets are upside down/
Bruce,Upstate NY is offline   Reply With Quote
Old 11-15-2012, 06:32 PM   #12
TinCup
TinCup's Avatar
I don't know where you got the replacements but here is a great example of what I call "Crap Parts". The smaller pads came for Obsolete Ford here in OKC and the correct size parts came from Mike's in Georgia. They were like you describe.
TinCup is offline   Reply With Quote
Old 11-15-2012, 07:16 PM   #13
Don S
TinCup,what thickness were the correct ones ?
Old 11-15-2012, 07:31 PM   #14
TinCup
TinCup's Avatar
Sorry Don I didn't measure them. The ones I replaced had compressed to around a half inch. I can tell you that the top ones pictured fit correctly.
Old 11-15-2012, 10:16 PM   #15
Don S
Tincup,top ones are not a problem if a little off in thickness,but for me the bottoms were too thick to get good alignment of starter push rod.If yours compressed that much,they were a lot softer rubber than mine.
