07-31-2013, 12:17 PM | #1 |
carborator cleaning
Search didn't provide any help,so the question is what can carb bodies be soaked in that will remove the crud ( rust,dirt, grease etc ) from all the passageways of the carb body The brass float hanger is to be concerned with so whatever the cleaner is shouldn't harm brass.I have several that need cleaning before rebuilding. Thanks
07-31-2013, 01:57 PM | #2 |
Re: carborator cleaning
Molasses eats the rust without hurting the brass. I seem to recall Vince had shown some pictures of a nicely cleaned carb by using electrolysis. I've been sandblasting my carbs and blowing through the passages. I've had to remove the brass plugs on some carbs. I wonder how Derusto would work?
07-31-2013, 02:05 PM | #3 |
Tell us about molasses, do you thin it with water and how long can a part soak?
07-31-2013, 02:26 PM | #4 |
I'm not sure with houshold liquid molasses, but I went to the feed store and bought a large bag of dry animal molasses. As I recall I used one pail of molasses and about 4 pails of hot water and stir it up. Then drop in the rusty parts with no grease or oil on them. I used a dark blue plastic tub and set it in the hot summer sun for about a week. Then pull out the parts and rinse with hot water and blow dry. Flash rusting will begin immediately, so paint, oil, or plate the parts right away.
07-31-2013, 05:43 PM | #5 |
Molasses contains phosphoric acid. It a small amount. Just get some acid and not mess with the gooey, sticky stuff. No magic here, just phosphoric acid.
Pete's Ponies Mustang RUSToration & Performance |
07-31-2013, 06:24 PM | #6 |
Takes some time but it has worked well for me.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
07-31-2013, 06:49 PM | #7 |
I used a 50/50 mixture of white vinegar and water...let them soak overnight...happy with results
07-31-2013, 07:09 PM | #8 | |
Chief tole me about those "little men" that runs in the wires, makin' electrical things happen, but he forgot to tell me about those "little kids" in the carbonator!
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 07-31-2013 at 08:05 PM. |
07-31-2013, 07:56 PM | #9 |
Straight ammonia works really good! Soak for a day of two. They say after about 5 days, it could hurt the brass.
07-31-2013, 09:11 PM | #10 |
Thanks for the suggestions,I will post results.
07-31-2013, 09:37 PM | #11 |
Here's what I do:
1. Use engine cleaner and a wire brush to clean off the dirt, then rinse off with hot water. 2. Dismantle and remove bottom plug, jets, and choke & throttle plates. 3. Blow passages clear with the spray nozzle of carb cleaner and small brushes and pieces of wire. 4. Soak overnight in a lid-covered gallon paint can full of acetone to remove fuel residue and external paint. Remove and blow out passages with compressed air. 5. Place in a sealable plastic container with enough Rustsolve to cover and leave overnight. Then, rinse and brush surfaces under hot water. 6. Place back in the acetone bucket for an hour, remove and blow dry. You now should have a paint, gunk, and rust free casting. |
07-31-2013, 09:48 PM | #12 |
Thanks Ursus, another choice
07-31-2013, 10:08 PM | #13 |
In 1960 when I was a senior in high school I took an auto shop class hoping to learn something about auto repair and maintenance. As it turned out, most of the class could barely read the text book so most of our time in class was spent reading out loud and taking spelling tests. That's where I learned to spell carburetor. I mean no disrespect, I guess I'm just showing off.
