Old 06-13-2019, 09:50 PM   #1
tombarb33
Default 1933 Ford Headlights
I have 2 sets of 33 headlights. One pair is all stainless steel and the other is stainless except for the internal front lip where the lense fits. This part is mild steel. Once the front ring is attached the headlights look identical. The external markings are also identical. Is one pair an earlier version or something?
tombarb33 is offline   Reply With Quote
Old 06-13-2019, 10:42 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 1933 Ford Headlights
I will have to look at my extras and see how they are made. DavidG will certainly know the answer to your question. Maybe different "cottage industry" manufacturer?
Old 06-13-2019, 11:40 PM   #3
DavidG
DavidG's Avatar
All of the original '32-'34 headlamp buckets that I've ever seen have un-plated plain steel inner rings where the reflector attaches. I believe that was by design to ensure good grounding. My guess would be that the pair with stainless rings have had them replaced.
DavidG is online now   Reply With Quote
Old 06-14-2019, 03:21 AM   #4
33rds
I dont have any, but i have seen as you describe, completely in stainless. no loose ring but in one piece
It was here in Sweden, but most is with loose ring here to.
But i have no Idea if It is à Europen thing, or early late?
33rds is offline   Reply With Quote
Old 06-19-2019, 01:13 AM   #5
Manuel
I have a couple of old 1933-34 headlight buckets. A magnet will attach to some and not others??
Manuel in Oz
Manuel is offline   Reply With Quote
Old 06-19-2019, 01:59 AM   #6
koates
Manuel in Oz
I have several sets of 1934 only headlamps , all are originals and some are magnetic and some are not. Regards, Kevin.
koates is offline   Reply With Quote
