Old 06-08-2017, 04:01 PM   #1
Rparker28
Default Radiator Rods w/drainage tray?
All- Took my radiator out today and attached to my radiator rods is a tin tray. Is that factory or something that someone put on? I understand the principle but is it factory? There was a piece of leather at the top of the tray as well,Ralph
Rparker28 is offline   Reply With Quote
Old 06-08-2017, 04:40 PM   #2
daveymc29
daveymc29's Avatar
Default Re: Radiator Rods w/drainage tray?
Not an item I have seen before. Certainly not a stock part for any Model A I have been associated with.
daveymc29 is offline   Reply With Quote
Old 06-08-2017, 06:30 PM   #3
ursus
In some areas known for high rainfall devices like this were used to keep water from draining through the hinges and into the ignition components. I recall seeing such a device in some older heavy equipment in coastal British Columbia.
ursus is offline   Reply With Quote
Old 06-08-2017, 07:03 PM   #4
Rparker28
Thanks.......the car came out of New York. That might explain it. When I put it back together I am going to put it back,Ralph
Old 06-09-2017, 07:31 AM   #5
jb-ob
While not a 'factory' part, a similar item was installed on A616 for it's December 1928 winter crossing from Detroit to LA and up the West Coast displaying 'The New Ford's' all weather driving abilities.
JB
jb-ob is offline   Reply With Quote
Old 06-09-2017, 08:20 AM   #6
Richard Lorenz
That tray might help a little bit toward keeping the engine dry, but I believe that much more water comes into the engine compartment through the radiator in a heavy rain.
Richard Lorenz is offline   Reply With Quote
Old 06-09-2017, 08:38 AM   #7
Big hammer
Good keep it original the way it came to you, a conversational piece for sure :-)
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 06-09-2017, 04:23 PM   #8
Rparker28
Thanks everyone.........conversation piece for sure. The owner also nailed a piece of rubber mat to the back seat floorboard as you step in the car. It is on both sides and nailed down. He was thinking that is for sure! Ralph
Old 06-10-2017, 10:21 AM   #9
Ray in La Mesa
I did the same thing back in college after a deluge/flash flood killed my engine in the desert. Made an aluminum tray w/ copper down tube as that is all I could find. Haven't been in that bad of a storm since.
Ray in La Mesa is offline   Reply With Quote
Old 06-10-2017, 08:33 PM   #10
Rparker28
It is definitely unique.......I wonder if it led to cylinder one being stuck? Ralph
Old 06-10-2017, 09:06 PM   #11
Railcarmover
Handy as a pocket on a shirt for putting tools and such on when your working on it I imagine.
Railcarmover is offline   Reply With Quote
