Old 11-13-2020, 09:16 AM   #1
packrat6
Default roof replacement
Next project on my '30 fordor is replacing the roof material. There seems to be a lot of differing opinions on what materials to use and where they go.
My questions are:
Should there be a fabric layer between the ribs and the chicken wire? If so, what fabric?
Should there be a fabric layer between the chicken wire and the padding? If so, what farbric?
What is the best sealant to use around the edges of the vinyl and on tack heads?
I understand there is a good video covering this install on "abarnyard" but cannot seem to access it. Suggestions on how to access OR on another video option?
Input appreciated.
packrat6 is offline   Reply With Quote
Old 11-13-2020, 09:46 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: roof replacement
My questions are:
AShould there be a fabric layer between the ribs and the chicken wire? If so, what fabric?
BShould there be a fabric layer between the chicken wire and the padding? If so, what farbric?
CWhat is the best sealant to use around the edges of the vinyl and on tack heads?
Input appreciated.
A: No fabric is necessary between the ribs and the wire. You can use friction tape in this area if you like.
B: A heavy Duck Muslin cloth. I typically use 10 oz. This is just to support the Cotton padding.
C: Any rubberized Seam Sealer (available at automotive body shop supply stores) is good. It is typically frowned upon to use Silicone as it sometimes promotes rusting of the sheetmetal.
D: I never knew that Marco had any videos on his website.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-13-2020, 10:17 AM   #3
1930artdeco
1930artdeco's Avatar
A shameless plug for my club But the Diablo A's put out a video on how to do a top on a 31 slant which you can buy through MAFCA, vendors or download on our website.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-13-2020, 11:00 AM   #4
Tacoma Bob
Tacoma Bob's Avatar
Indeed, Marco had the best tutorial I have ever seen.
Tacoma Bob is offline   Reply With Quote
Old 11-13-2020, 11:09 AM   #5
Bob C
Here's a link to Marco's tutorial. https://web.archive.org/web/20140906...finstall-1.htm
Old 11-13-2020, 11:16 AM   #6
Ed in Maine
Now I know some of you are going to yell at me for not using original materials but on the tops I have replaced I used 1/2 in. galvanized metal cloth (it is a mesh with 1/2 in. square openings). It is much tougher than chicken wire and less apt to get a depression if something falls on the top. Ed
Old 11-13-2020, 01:16 PM   #7
packrat6
thanks for the link bob C. it hooked me up......don't know why the other links i used didn't work but maybe because my computer is older than the car i'm working on.
