07-19-2017, 06:58 AM | #1 |
1933 ignition resistor wiring?
OK, on the inside firewall, I have a fuse block plate. It has the resistor to the left, and a single fuse bracket on the right. The 2 red ignition switch wires are connected to left side of resistor mounting bolt. Seems as it should have 1 red wire on left side, and 1 red wire on right, bypassed resistor? Correct? Thoughts? Thanks
