10-22-2020, 08:56 AM | #1 |
Wiring question
Do the wire connectors on the wiring harness for example the headlights pull apart or are those crimp connections?
10-22-2020, 09:05 AM | #2 |
Re: Wiring question
Ford used what are referred to a bullet connectors. And yes, they pull apart.
10-22-2020, 09:08 AM | #3 |
Re: Wiring question
Be sure to use dielectric grease when connecting those bullets. They oxidize very easily and easily loosen.
10-22-2020, 09:17 AM | #4 |
Re: Wiring question
So they should pull apart?
10-22-2020, 09:36 AM | #5 |
Re: Wiring question
If you have original wiring, they do pull apart. The connectors have a "spring loaded" sleeve with ridges inside to "lock" into the groove in the male connector and a rubber cover over the sleeve. Over the years, the rubber becomes very hard, and will sometimes make it difficult to pull the connector out of the sleeve. Dennis Carpenter has the wiring connectors in their catalogue.
10-22-2020, 10:29 AM | #6 |
Re: Wiring question
https://www.google.com/search?q=how+...hrome&ie=UTF-8 Last edited by 19Fordy; 10-22-2020 at 10:39 AM. |
10-22-2020, 06:54 PM | #7 |
Re: Wiring question
Thanks for the info. I have fog lights on my car now, the last guy tried to use them for directionals, will not work because they draw too much. I want to hook the fog lamps up for day time driving lights, when hooked direct to 6v they are bright. I want to use the parking lights inside the headlight cans for the directionals. Also want to put in led tail lights as well as a third brake light.
10-22-2020, 07:48 PM | #8 |
Re: Wiring question
You might want to look at the wireless directional package made by Egypt Garage; Leno’s workaround of choice for simple addition of directional
No job’s done ‘til it’s all done |
10-22-2020, 07:51 PM | #9 |
Re: Wiring question
I already have the directionals installed and all the wires have been run so I just want to change a few things
