Old 03-03-2012, 01:16 PM   #1
charles in east texas
charles in east texas's Avatar
Default 53 Ford p/s
I just finished installing new seals in the control valve and a new seal in the cylinder. Put it all back on the car, added fluid, etc. Now I have no assist when turning to the left, but turning to the right everything seems O.K. Turning to the left, it is just like I have no power steering. Air pocket? The car drives fine going down the highway. The steering wheel returns as normal after a left or right turn. The trouble shooting guide is not helpful. Any ideas. Thanks for any suggestions. Charles
charles in east texas is offline   Reply With Quote
Old 03-03-2012, 02:03 PM   #2
Shadetree
Shadetree's Avatar
Default Re: 53 Ford p/s
This was the most helpful video on power steering I have seen. I may have seen it first on this forum. If you know all of this already forgive me, if not, it may help you trouble shoot the problem.
https://www.youtube.com/watch?v=AlpvyWAA8a0
Shadetee
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 03-03-2012, 03:27 PM   #3
W E Mack
Where can I find more of these old military videos? That is a great historical resource there.
W. E.
W E Mack is offline   Reply With Quote
Old 03-05-2012, 11:21 AM   #4
Shadetee
Thanks Shadetree for the help. I looked at all of the videos. Come to find out I did not have the valve spool nut properly adjusted inside the valve control. P/S works as it should now. Thanks again for your help. Charles
