Old 01-07-2012, 11:08 PM   #1
charles in east texas
charles in east texas's Avatar
Default 36 ford
What does LB stand for when referring to the motor and do you have to remove the body to replace the floor from the seat area forward. Thanks, Charles
charles in east texas is offline   Reply With Quote
Old 01-08-2012, 09:30 AM   #2
dave collette
dave collette's Avatar
Default Re: 36 ford
Hi Charles,The LB stnds for loose bearing.This means that it has insert main bearing that can be replaced.Yes you can changr the floor pan on the frame .I have done this. Dave Collette [email protected]
dave collette is offline   Reply With Quote
Old 01-08-2012, 10:01 AM   #3
38 coupe
38 coupe's Avatar
Default Re: 36 ford
LB has also been thought to stand for large bearing since the insert bearings are larger diameter than the poured bearings. Ford literature lacks a definition, so LB can stand for whatever you want.
Old 01-08-2012, 01:03 PM   #4
Default Re: 36 ford
Thanks fellows. Just learning about the 36's. Yes I have the book. I will have many more questions I sure. Thanks again, Charles
Old 01-08-2012, 01:23 PM   #5
Mike in AZ
Mike in AZ's Avatar
Default Re: 36 ford
good luck, Charles....any pics??... ... Mike
Mike in AZ is offline   Reply With Quote
Old 01-18-2012, 08:54 PM   #6
Don DeLong
Default Re: 36 ford
I thought lb stood for long block and sb stood for short block.
Don DeLong is offline   Reply With Quote
Old 01-18-2012, 09:12 PM   #7
ken ct
Default Re: 36 ford
LB = loose bearing,large bearing,and pound. lol. ken ct.
ken ct is offline   Reply With Quote
Old 01-18-2012, 09:17 PM   #8
jerry grayson
Default Re: 36 ford
The engine log book at the Benson Ford (archives) refers to LB as Large Bearing.
jerry grayson is offline   Reply With Quote
Old 01-18-2012, 10:21 PM   #9
Default Re: 36 ford
Jerry, is there any to tell On the outside which engine I have? I know the car is a late 36.
Thanks, Charles
Old 01-19-2012, 12:23 AM   #10
columbiA
Default Re: 36 ford
I believe the oil pan is slighty deeper at the front to clear the larger main brg.
columbiA is offline   Reply With Quote
Old 01-19-2012, 08:10 AM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 36 ford
I always thought the oil pan was a little wider at the front on an LB. Some LB's are stamped LB on the surface of the block where the intake manifold is bolted. Some non LB's may also be stamped similarly by dishonest folks trying to make quick bucks. The best way to determine an LB engine is to remove the oil pan and measure center to center distance between main bearing studs. LB = ~ 3.250" and non LB = ~ 3.000". The absolute proof is to remove a main bearing cap and confirm that bearing is loose/removable. Some of our Australian and New Zealand friends (maybe Canadian as well) have reported having a hole in some area on front of block that signified an LB to them. I have never seen a US manufactured block that had that same hole.
John
Old 01-19-2012, 11:18 AM   #12
blucar
blucar's Avatar
Default Re: 36 ford
It has been written up in several books/articles that generally speaking the insert bearing LB engine, came out in mid-year '36, however, Ford had an abundance of babbit bearing blocks still in their system so they continued to use them.
I believe that I have read that the babbit bearing engines continued throughout the '36 Ford model run.
As stated in the preceding threads, the sure way to find out what engine you have is to open it up.
Bill.... 36 5 win cpe
Old 01-19-2012, 11:40 AM   #13
Charlie Stephens
Default Re: 36 ford
Then there is another good book, "The Early Ford V8 As Henry Built It" page 21, that says "In addition, starting in September 1935, a new block with new main bearing inserts was introduced (68-6010)". It also states (still page 21) "The 1935 block with the cast babbit bearings was continued to the end of 1936 production".
Charlie Stephens
Old 01-19-2012, 11:54 AM   #14
Lawson Cox
Lawson Cox's Avatar
Default Re: 36 ford
i agree with Charlie. If you have the original heads on your engine you can tell pretty quickly. Domed pistons first came out with the LB engines. If you have an LB engine the heads should have a 48 part number prefix, Flat top pistons would have a 40 prefix.
Old 01-19-2012, 03:08 PM   #15
JM 35 Sedan
Default Re: 36 ford
I have an original never been torn down (until I removed heads), '36 Ford LB engine removed form an original '36 1/2 ton PU, w/original 3-1/16" bore, minus some slight wear, that has flat top pistons. Heads are only marked with Ford script logo. No part numbers. The truck was purchased from the original owner who kept this truck on a farm not far from Baltimore, MD. Some pictures are attached.
John
