Old 04-12-2015, 11:37 AM   #1
steven a
Default truck beds
On a 1949 and 50 ford half ton was did one bed come with a wood floor and the other steel ? and how should the ser. # start Thanks for the help Steve
steven a is offline   Reply With Quote
Old 04-12-2015, 01:50 PM   #2
CA Victoria
CA Victoria's Avatar
Default Re: truck beds
Here is a site dedicated to our F1 pickups. Ford Truck Enthusiasts. Several of the guys socialize on both FB and FTE forums.
http://www.ford-trucks.com/forums/forum41/
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 04-12-2015, 03:08 PM   #3
cmbrucew
cmbrucew's Avatar
Mid year 1950 I believe.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 04-12-2015, 03:30 PM   #4
Barry-ct
Barry-ct's Avatar
Yes, mid 1950 was the switch. early ones had the steel floor with wood underneath. The sides had stamped raised panels. also had a floor shifter. Late ones had a column shift, smooth bed sides and wood floor. These changes may have happened at different dates. Hard to say after 65 years.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 04-12-2015, 08:11 PM   #5
mtflat
mtflat's Avatar
serial prefix for both 49 and 50 start with 98RC or 97HC - the only way to tell which year is by the serial number itself.
if you have stampings on the firewall you can figure color, assembly plant and date of assembly
mtflat is offline   Reply With Quote
Old 04-13-2015, 05:32 AM   #6
FortyNiner
FortyNiner's Avatar
Are you trying to determine the YOM for a specific truck?
FortyNiner is offline   Reply With Quote
Old 04-13-2015, 11:17 AM   #7
steven a
the year
Old 04-13-2015, 09:33 PM   #8
mtflat
mtflat's Avatar
send me a pm with the serial number and I can tell you the year.
Tim
Old 04-13-2015, 09:38 PM   #9
Ross F-1
Ross F-1's Avatar
I thought the metal floor vs wood floor was a change made at a different time than the embossed side panels vs. straight bed panels?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
