12-16-2021, 10:50 PM | #1 |
Anderson Intake
Looking for information on an Anderson 4 bl intake manifold.
Gramps |
12-17-2021, 08:29 AM | #2 |
Re: Anderson Intake
Anderson Automotive they made a two piece intake. Besides the four barrel top the design allowed the option of adding a two carb or three carb top to the lower section. If that's the one your looking for I have one available with the four barrel top on it.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 12-17-2021 at 09:04 AM. |
12-17-2021, 10:52 AM | #3 |
Re: Anderson Intake
Thankyou very much. Be nice to see what's inside. Yes, I know it comes with other covers. What I was interested in was how they did the 180 deg firing order, which I see it is. Tks again.
Gramps |
12-17-2021, 11:22 AM | #4 |
Re: Anderson Intake
First one I have ever seen. Looks like the 4bbl is back farther than the current ones available.
12-17-2021, 01:12 PM | #5 |
Re: Anderson Intake
My guess, making room to run a generator in the front - like we do on many early V8 cars.
12-17-2021, 03:21 PM | #6 |
Re: Anderson Intake
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-17-2021, 03:41 PM | #7 | |
Re: Anderson Intake
I love the concept behind the Anderson design. Switch around tops for different applications. Seems like a smart idea. |
12-17-2021, 04:15 PM | #8 |
Re: Anderson Intake
yep
12-17-2021, 04:40 PM | #9 | |
Re: Anderson Intake
Switching around tops First use the four barrel top for work and economy. Then switch over to three deuces for those fun evenings street racing. Good times all around. Ronnieroadster
12-17-2021, 09:04 PM | #10 |
Re: Anderson Intake
Thanks RR and 51 Merc, You just sold it. I'll call him tomorrow. Be nice to have a 2 duce top. but could probably make one.
Gramps |
12-17-2021, 11:17 PM | #11 |
Re: Anderson Intake
Seems like cylinders #4 & 5 would likely run a little leaner than others, as might #1 & 8 also. Quite a novel design, though. DD |
12-17-2021, 11:34 PM | #12 |
Re: Anderson Intake
Pobodys Nerfict
G |
12-17-2021, 11:47 PM | #13 | |
Re: Anderson Intake
It appears that (1) of the (3) ports have to be feeding the forth cylinder on each side.
12-18-2021, 12:27 AM | #14 |
Re: Anderson Intake
YES, i saw that, however, I doubt very much if it would bother a street engine, and it is quite rare.
12-18-2021, 12:31 AM | #15 | |
Re: Anderson Intake
I concur! I'd guess that #5 feeds #1, and #3 feeds #8. DD . |
