02-23-2021, 03:49 PM | #1 |
Lock it or Lose it
Hi All,, OK I searched the topic and could not find the answer. I have a NOS Hurd lock cylinder for my 41 pickup ignition. Someone has removed the original and drove a wood dowel in its place I assume to hold the lock pin up. My question is what supposed to hold the cylinder in the drop? I see a hole in the back side of the drop , it appears that something should go in it and into the side of the cylinder but what.? I see no threads in the hole. Thanks
02-23-2021, 04:01 PM | #2 |
Re: Lock it or Lose it
A pin is used to hold the lock cylinder in the housing. It's press fitted into the small hole in the column drop.
Ever stop to think and forget to start again? |
02-23-2021, 04:42 PM | #3 |
Most of the time when you find a cyl out that has been out for years, the pin has been drilled out. Original pins are available I believe from some of the vendors. If drilled out, you may need to tap the hole and put a setscrew in.
02-23-2021, 04:49 PM | #4 |
The last one I did, my 34, someone had drilled it, and wallowed the hole considerably. A #12-28 was the smallest I could go with. Personally, I wouldn't go with the pin. If I would ever want to service it in the future, it's easier to deal with a set screw. IMO
02-24-2021, 09:46 AM | #5 |
Thank you all, Looks like someone drilled out my pin as the hole is over 1/4" and sloppy. So this will be a little more involved then I thought. But we do love a good challenge don't we? Thanks again, Tim
02-24-2021, 10:18 AM | #6 |
You don't want to drive around with a missing lock cylinder as that would allow the locking pin to drop and snag the shaft and lock the steering shaft...... not good at all.
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
02-24-2021, 02:12 PM | #7 |
I've always tapped it for a set screw, same with the break off bolt that pins the column drop to the column.
