01-10-2022, 10:34 AM | #21 |
Re: Can you id this ford.
It looks pick up to me too. I thought only the trucks used the horizontally mounted oil filter.
01-10-2022, 10:48 AM | #22 |
was not a pickup i recall. thanks to all for pitching in. scott
01-10-2022, 11:47 AM | #23 |
It's a 352 in a 65-66 F100
01-10-2022, 11:49 AM | #24 |
It's a 352 in a 65-66 F100. The angled oil filter, hand choke and flat top valve covers are the indicators
01-10-2022, 12:56 PM | #25 |
If the alternator and carb/intake are original...., I believe alternators started in 64 1/2 or '65. The carb appears to be a four barrel 4100 and the style accel pump cover that was used after '64. Definately an FE engine. My Guess is a '65 or '66 Galaxie with a 390, since 352's didn't use a four barrel carb after 1960.
Sal |
01-10-2022, 01:00 PM | #26 | |
Good catch on the manual choke. At first look I thought the choke assembly was just missing. Also thought V8 trucks had auto chokes in '66 ? Could be wrong. Sal |
01-10-2022, 01:22 PM | #27 | |
Hey Scott, is there a chance you could go out and snap a picture of' that vehicles body ? .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
01-10-2022, 01:55 PM | #28 |
Sal, I've had a '65, '66, and a '67 F100. All were original 352's with manual choke 2100's, alternators and the squared top valve covers. This photo is definitely a pickup from those 3 years. In '68 the pickups got a 360, 2100 with an auto choke and the rounded, Powered by Ford valve covers. I just don't have a picture of any of my old rigs to verify it
01-10-2022, 03:32 PM | #29 | |
Good info Craig. This engine has a 4100 4 barrel. That's why I'm leaning towards a 390. Chances are the carb and intake have been chaged after all theses years. I don't know if a 390 was ever offered in a truck ? Sal |
01-10-2022, 04:50 PM | #30 |
Are you sure you are not looking at a 2100?
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
01-10-2022, 05:16 PM | #31 |
Take another look Sal, I can see the rear of the mounting flange, and I can't see anything that looks like the secondary throttle plate activator rod that would be on a 4100
01-10-2022, 05:52 PM | #32 | |
All I can say is someone must have disabled the rear two barrels by removing the rod that comes from the diaphragm lever. Actually, after a better look I can see the tip of the sec. diaphragm lever. Not to mention one of the secondary bowl vent tubes sticking up. Sal Last edited by scicala; 01-10-2022 at 05:58 PM. |
01-10-2022, 06:01 PM | #33 |
01-10-2022, 06:20 PM | #34 |
As others have mentioned, those are truck inner fenders. I agree with craig narrowing it down to 65 or 66.
01-11-2022, 12:08 AM | #35 |
Sal, take a look at this carb. I think the castings at the rear are what you think are screws Whoops, no picture!
01-11-2022, 12:14 AM | #36 |
https://st.hotrod.com/uploads/sites/...rebuild-02.jpg
Sal, go to this site and you'll see the picture |
01-11-2022, 09:51 AM | #37 |
I thought it looked like a 2100 as well. As I remember only the 289 HiPo's were the only 4100 that have manual chokes. And its not a 289! Hard to tell what the carb is for sure.
01-11-2022, 10:54 AM | #38 |
Friends & family owned Galaxies, LTD, and Mercury Monterey cars in 65 & 66 and I spent time working on them. They don't look like the one in the photo for sure. My Pop had a 66 Ford F100 that looked a lot like what's in the photo. They had the twin I beam front ends.
01-11-2022, 11:31 AM | #39 | |
Sal |
01-11-2022, 11:56 AM | #40 |
thanks again. i will return in time and update if anyone is interested. i really don't remember it to be a pickup but i have no memory left.
