12-09-2021, 09:46 AM | #1 |
Original Grease Gun Repairs
Does anyone know where I can buy a repair kit for my original Model A grease gun. The plunger is worn and does not function as it should. Thanks
12-10-2021, 03:21 PM | #2 |
Re: Original Grease Gun Repairs
Do you have the cork plunger or leather plunger?
12-10-2021, 03:45 PM | #3 |
Following
12-10-2021, 06:23 PM | #4 |
Make sure you keep it well greased.
12-11-2021, 12:32 PM | #5 |
Not sure if it is cork or leather, I will check..
12-11-2021, 01:55 PM | #6 |
David Serrano |
12-11-2021, 03:51 PM | #7 |
Most seem to be leather but I have seen cork plunger. The leather is a “gasket” between metal, the cork is a tapered plug type plunger maybe an inch or so thick.
12-11-2021, 05:38 PM | #8 |
Did you take the end apart to see if the check valve (ball bearing and spring) are intact and functional? The plunger merely acts as a follower to keep the grease moving toward the business end.
12-11-2021, 07:08 PM | #9 |
When I attempt to use it, the grease mostly slips around the plunger while a tiny bit appears at the nozzle. I am pretty sure it is the plunger. Have not had a chance to check yet but if it is leather it might be an easy fix.
12-12-2021, 09:11 AM | #10 |
Hold and press straight against the zerk, then pump!
