03-14-2021, 02:40 PM | #1 |
(Help Source) For .100 over Piston rings 255 engine
Help I need a ring set for 255 eng. at .100 over. Both Reds Headers, and Van Pelt are a "no go". I am now over 80 Yrs, and I have had this set of TRW 4 ring pistons that are fit up to good rods for over 60 yrs. Engine was run for one year. cold Idaho winter froze and broke the block. I then sold all I could sell, and kept the crank rods and pistons. I am going to put together a Flathead and would like to use these parts. I am unable to find a 4 Ring set to fit the pistons. Thanks for any help that I can get. I do not think Flatheads will ever die, and some of us old fools should be so lucky and run so good. David
Long Range Last edited by David Lien; 03-15-2021 at 11:39 AM. |
03-14-2021, 03:12 PM | #2 |
Re: Source .100 over Piston rings 255 engine
If you want 4 rings you will need to buy 2 sets
Or just run with three rings is what i was told by Rich at AER in Skokie Il. The two bottom ones are the same Sent from my iPhone using Tapatalk |
03-14-2021, 03:25 PM | #3 |
I have a 3 ring set. You can leave the bottom ring off. This is how I build my engines.
03-14-2021, 04:39 PM | #4 |
Check with Egge in California they should be able to help you ith rings.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-14-2021, 07:14 PM | #5 |
Very hard to find and harder for a 3 1/16 .
"Came too close to dying to stop living now!" |
03-14-2021, 07:49 PM | #6 |
03-15-2021, 05:36 AM | #7 |
Hastings discontinued the 3-3/16” + .100 early this year. The 80 and 125 sizes are still available. Grant still seems to be MIA since they made the production move from California to Mexico.....no product has come out of there that I am aware of since the move.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
03-15-2021, 12:02 PM | #8 |
Re: (Help Source) For .100 over Piston rings 255 engine
Its been a chore getting rings and many other parts lately
03-15-2021, 12:12 PM | #9 |
Here in NZ had trouble sourcing some piston rings. Ended up getting them made locally.
Win Win. Good price and local business was supported. Phil NZ |
03-15-2021, 12:25 PM | #10 |
