05-10-2010, 02:12 PM | #1 |
6 volt resistors
Hello.I,am a relatively new Flathead guy,who,s been restoring a 1940 Merc. Tudor.Just had Bubba,s build me a simpler to install crab style resistor as I fryed the points on the old helmut style.I understand thier is a resistor i need.Everything is stock,and it was starting and running fine for awhile on the old setup,but I,am told that I may have bipassed the needed resistor.Where is that exactly and where can I get another?Really appreciate your help!!!!Jon
05-10-2010, 04:37 PM | #2 |
Re: 6 volt resistors
Most years under the dash area...'33-46 on firewall area next to fuse or breaker, '32 on tunnel stampings, '47-8 atop coil. Yours would be on firewall inside near the hole where big wiring harness comes through. Measure voltage at coil terminal when running and warm should be around 4, if 6-7 resistor isn't in the circuit. Reistors /32-48 are interchangeable. NAPA ICR-40, Standard FD-220, do not know if still available, go to early Ford parts places if not. Joblot automotive.
05-10-2010, 06:40 PM | #3 |
Thankya my brutha!!!!
05-11-2010, 12:18 AM | #4 |
Here it is on a 39 pickup or panel. The resistor is on the left
05-11-2010, 12:41 AM | #5 |
how did you post pic with your answer thanks trev
05-11-2010, 07:36 AM | #6 |
Gary in Mozarks |
05-11-2010, 08:03 AM | #7 |
I was in my local NAPA store late last week looking for a later model ignition resistor. Their catalog still shows the older style ignition resistor as being available. Appeared to be an exact replacement for the stock one for a '46. FWIW
05-12-2010, 04:50 AM | #8 |
Thanks again fellas!!!
