Old 04-20-2020, 05:21 PM   #1
TK in LA
TK in LA's Avatar
Default B crank Bearings Who's are they?
Hi guys. Here is my problem. I have a B motor that was rebuilt a long time ago and had insert bearings installed on both the rods and into the main bearings. I'm in the process of rebuilding do to a water leak in the front of the block casting. That part has been fixed and I re-sleeved the block back to standard and it has a fresh valve job on a hardened seat set of Chevy (?) valves with adj. lifters. Here in lies the problem: the mains and rods were both shimmed even though they are inserted. The crank is close but to far out to remove the shims. I'm going to grind the crank to the correct clearances but I'm having difficulty finding the correct bearings. The rods are old AER bearings and I have a question in to them if they are still the same as there latest design. The problem is the mains. Other than a small G in a circle. there is a P/N of C3J C . I have no idea who's bearing they are or what they fit to replace them. They used two sets of bearings on the rear main and the center. Any ideas? Pictures show the markings.
TK in LA is offline   Reply With Quote
Old 04-20-2020, 05:38 PM   #2
MrBruce
MrBruce's Avatar
Default Re: B crank Bearings Who's are they?
TK these are Glacier bearings. Do a search on the internet and you will find the Number
https://www.bing.com/images/search?q...J++C&FORM=IGRE
See if this will take you to them, if not just search for Glacier Engine Bearings
MrBruce is offline   Reply With Quote
Old 04-20-2020, 05:40 PM   #3
Dodge
The brand name is Glyco but I don't recognize the part number, it could be a date
code.
I know in the early days AER engines used this type of set up. You should give him
a call.
Dodge
Dodge is offline   Reply With Quote
Old 04-20-2020, 07:08 PM   #4
TK in LA
TK in LA's Avatar
Mr Bruce and Dodge, Thanks for the leads. After further investigation, every bearing has a different marking. See attached. last 2 are the same bearing as is the two pictures before them. I haven't done a search on these yet. Different manufacturers as well. Someone must have been using what ever they had laying around. Thanks again for taking the time!
Old 04-20-2020, 07:27 PM   #5
TK in LA
TK in LA's Avatar
I haven't found the correct number yet but the last pictures show some numbers that look like they cross to Vandervell bearings for an MG Mk2? More research!
Old 04-20-2020, 07:28 PM   #6
Dodge
The 4547 is a Vandervell bearing company bearing. It a a main bearing for an MGA 1622
motor. So that 12H676 is probably the same MGA bearing.
H&H used to also do it this way.
Dodge
Old 04-20-2020, 08:06 PM   #7
johnneilson
The Vandervell VP817 is the MGA 1622 which crosses over to a MS-1055G nissan
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is online now   Reply With Quote
Old 04-20-2020, 08:56 PM   #8
TK in LA
TK in LA's Avatar
Dodge, You're probably pretty darn close. This was a local SoCal car the motor came out of so it very well could have been a H&H motor. Now I just need the clearances for the crank to bearings and see if I still need to go to a .040 under bearing if they're available.
Old 04-20-2020, 08:59 PM   #9
TK in LA
TK in LA's Avatar
John, Thanks for the cross over number. Now I need to find out what Nissan they fit. Lots of research to do. I may even contact H&H and see if they are any help. Again, Thanks to all who checked out my problem and contributed to by previously unknown path to the future.
Old 04-20-2020, 09:30 PM   #10
johnneilson
Tom,
too easy;
MS-1055G STD
Nis: 1189(61-66), 1299(65-1969); NisTrk:
1299(68-1969)
Contents: (3)MB-602G
housing bore is 2.146
most newer bearing catalogs do not go back early enough to find the listing.
the metric undersize .25mm = .010 imp
.50mm = .020
.75mm = .030
King bearing makes current bearing in alum, MB-347AM
John
Old 04-20-2020, 11:38 PM   #11
TK in LA
TK in LA's Avatar
John, Your the man!!@ will try and get some ordered in the next couple of days.
Best regards to all!!
Old 04-21-2020, 03:43 PM   #12
TK in LA
TK in LA's Avatar
Just some added pictures of the original layout. As you can see the block bearings in the front and center main use two narrower bearings per spot (Vanderville 4921 / 140111) and a larger single bearing in the cap (Vanderville 4547/12H676). This same bearing is utilized in the rear main cap and block but two the the bearings have .110 taken off one side to clear the added on thrust washers. I guess this will work OK once I can get all the correct parts? Anyway, it's always a thrill to figure out someone else's madness.
Old 04-21-2020, 03:54 PM   #13
MrBruce
MrBruce's Avatar
TK
You might want to just call Rich at Antique Engine in Skokie, Il...he has inserts for the Model A and B engines. The thrust washers and everything is there. You have to buy the rods with it as they are made for the inserts. We used a lot of Volvo bearings in the Model A (as I would send them to guys) when I was with Clevite Engine Bearings. REM in California would get me to send him a lot of bearings as he was inserting them for years. I don't think he is around anymore?
Old 04-21-2020, 04:08 PM   #14
TK in LA
TK in LA's Avatar
Thanks Mr Bruce. I sent an inquiry to AER on the bearings for the rods. The rods have the AER stamp on them just not sure if they are the same. Hate to buy a set or rods just to get bearings. As for mains, if the bearings they sell are different than thos installed it may mean the block will have to be re-machined if possible. Lots of challenges. Good thing we're on lock down>
