02-20-2016, 12:59 PM | #1 |
'47 Axle Key install location
I know I need to clean up the grease and such but which is the correct install location, closer to threads or further from threads?
The reason I ask is when I install the hub and torque down on the axle nut it pushes the wheel hub up against the backing plate so the wheel hub no longer spins. I'm almost there I think... Last edited by em1davis; 02-20-2016 at 01:52 PM. |
02-20-2016, 02:54 PM | #2 |
Re: '47 Axle Key install location
Did you mean to say that when you tighten the nut, that it pushes the DRUM up against the backing plate?
The axle key actually has nothing to do with the amount of contact the hub makes with the axle, nor how far the hub slides onto the axle taper. The inside taper of the hub, AND the shape of the taper on the axle dictate where (inboard / outboard) the hub SHOULD sit on the axle. In fact, you SHOULD be able to mount the hub on the axle WITHOUT the key.......and it would not alter the hub's location, as opposed to mounting WITH the key. Your pictures are not the clearest, but they both show enough clarity to suggest that the taper on your axle is damaged, and that would certainly be a viable reason for your resultant symptom. There MAY also be damage to the taper inside your hub. DD |
02-20-2016, 03:32 PM | #3 |
You are attempting to install the key correctly. Moving forward would indicate it (key) is not the proper size or perhaps there is damage to the slot and / or the slot within the hub. I agree with V8COOPMAN that your axle looks well, less than desirable.
I would suggest you attempt to fit the drum / hub to the axle without a key. If it goes on properly, you most definitely have an issue with the key and or mating slot(s). You suggest the hub is going on too far... I doubt that is the case. It appears that the key is being pushed inward too far and thus preventing the axle from turning. That key should stay in the (near) position you show in the first photograph.
02-20-2016, 03:55 PM | #4 | |
(http://cgfordparts.com/ufolder/fordp...umber=01A-1105) I figured out that it isn't hitting the backing plate but the inside portion of the wheel hub where the bearing is contained is pushed up to push against the portion that the bearing rolls on. I was hoping that the key would help control how far back it went, but apparently not. (The 2nd picture is from me moving the key, it's not sliding around) My first thought was that the wheel hub where the bearing resides was longer than the hub that was on there, but it is the same. I guess it could be that the tapered portion of the wheel hub that goes on the axle is just a tad bigger allowing it to sit further on the axle and press against the back plate. The same problem exist if I don't have the key installed, I use my original hub without the key it doesn't show the same problem. Last edited by em1davis; 02-20-2016 at 04:25 PM. |
02-20-2016, 03:57 PM | #5 |
Kube makes some valid points above. That KEY just does NOT look "right"! Is it actually SQUARE in cross-section? DD
02-20-2016, 04:23 PM | #6 |
02-20-2016, 04:32 PM | #7 |
Here is what I have determined it touching... The wheel hub pressing against the part where the bearing should be rolling.
02-21-2016, 09:58 AM | #8 |
Try a axle shim.
02-21-2016, 01:01 PM | #9 |
Form the picture in post #6, it appears that your key is fairly worn and that there has been movement between the hub and the axle . . . which shouldn't exist. Maybe that's why you're changing hubs? In any case, I'd replace the key while I had it apart.
Henry |
02-21-2016, 01:12 PM | #10 |
A friend had the same issue with his new hub, I think he removed some metal from inside the new hub until he had adequate clearance and no more interference or rubbing. I would not use an axle shim if possible.
02-21-2016, 01:15 PM | #11 |
If you switch the drum/hub from the other side of the car do you still have this problem? It would be interesting to see if the hub you bought does not fit the other side of the car too. I bought hubs from http://www.mtcarproducts.com/Brakes.html and they fit. Who made your replacement hub?
02-21-2016, 02:50 PM | #12 |
IF, in fact, this is a REPRODUCTION hub as listed in your link, and IF it is TRUE that it actually is dimensioned INCORRECTLY, so that it rubs the end of the bearing surface as you surmise, then I'll ask the question again.......WHY CAN'T THE REPRO FOLKS BUILD STUFF THAT FITS? This thing lists at $225!
Where are ALL the guys NOW that usually want to kiss the repro guys butts for at least making parts that ALMOST fit? DD |
