08-30-2015, 02:50 PM | #1 |
'47 Brake Adjustment not as should be
So I've followed these directions
http://www.fordbarn.com/forum/showth...eak+adjustment But even with the adjustment all the way so that the shoes should not be touching I get a ton of drag. If I adjust the other direction I can lock the wheel up but I can never get it to spin freely without sound. Thanks for your thoughts Jason |
08-30-2015, 02:58 PM | #2 |
Re: '47 Brake Adjustment not as should be
Off on dragging or continues? New lining and turned drums or been run a while?
08-30-2015, 03:03 PM | #3 |
Try adjusting tight until wheel won't turn, then back off a few clicks and step on the pedal a couple times to center the shoes in the drum. Repeat until wheel turns with slight drag. Some sound is not uncommon and will not be a problem.
08-30-2015, 07:18 PM | #4 |
New shoes??
Drums turned?? Shoes arced to the drums?? Leading and trailing edges chamfered?? Paul in CT |
08-31-2015, 06:18 PM | #5 | |
Yes Yes New Drums Looks like they are Passenger rear wheel had no issues which is the picture The driver side rear wheel is the one with issues. |
08-31-2015, 06:31 PM | #6 |
08-31-2015, 07:29 PM | #7 |
08-31-2015, 09:12 PM | #8 |
I does look like your cable is crawling over the holding plate at the bottom? Maybe its just the picture.. Yes check the E brake I don't believe it pulls equally on both sides, I just had to do mine [adjustment].
08-31-2015, 10:18 PM | #9 |
is drum rubbing on backing plate edge?
09-01-2015, 08:12 AM | #10 |
Is it possible that the brake shoe lining is too thick?
Is the thickness the same as the front brake shoes? I remember years ago reading that there is a maximum brake lining thickness. For some reason, I think it was .20 in. Not sure though. Compare exactly the PASS side brakes with the DRIVER side brakes to find differences. Also, Is it possible that there is a malfunction of the wheel cylinder? Last edited by 19Fordy; 09-01-2015 at 08:49 AM. |
09-01-2015, 09:26 AM | #11 |
Could be a corroded wheel cylinder piston that is stuck in the bore. The aluminum pistons will become sticky if the fluid becomes contaminated with moisture. Pull the drum of a wheel that doesn't properly adjust. One or both sides of the cylinder will be stuck. The only cure is replacement of the cylinder. Don't bother trying to rebuild it.
09-01-2015, 09:55 AM | #12 |
Are all your brake springs new?
09-01-2015, 12:59 PM | #13 |
I just read in my 1935-48 Chilton Manual that the OEM brake lining of the 1940 Ford was .20 thick and the 1947 brake lining is 3/16 in. thick. The Brake shoe Clearance for both the 1940 and the 47 is: TOE .010 in. HEEL .006 in.
For more Tech Info. scroll down to BRAKES here. https://vintageautogarage.wordpress....948-tech-data/ The same info is and also shown below in BOLD black below. Brakes Service: Lockheed Hydraulic, self-centering, double anchor type. Hand lever applies rear wheel service brakes. NOTE—these brakes do not have anchor pin adjustment. Drums: Composite iron and steel. Diameter: 12”. Clearance: Least possible amount without drag. Lining: Width 1.75”. Thickness .187” Length per shoe 13.12” (forward shoes), 10.08” (rear shoes). Below is a photo of the right rear 1940 Ford brake set up. I know there is an anchor pin difference and an adjustment difference, but it seems your E-Brake cable is not allowing a smooth direct path to the brake shoe. Could that be impeding the proper adjustment and location of the rear shoes? And then there is the question: Are you installing the correct brake shoes for a 47 Ford? Stranger things have happened.Click on photo to enlarge. Last edited by 19Fordy; 09-01-2015 at 01:35 PM. |
09-01-2015, 03:57 PM | #14 |
Incorrect E- Brake arm it is to long.
09-01-2015, 05:55 PM | #15 |
I certainly looks like the emergency brake cable is hung up in the shoe anchors. Check the cable and the curved e-brake arm position carefully vs. the other side. Good luck.
Henry |
09-01-2015, 06:14 PM | #16 |
09-01-2015, 07:59 PM | #17 |
Well I pulled the wheel off which I was hoping to avoid.
I found 2 problems 1) as you can see by the image very carefully I'm not very bright at times. 2) The front shoe is not being moving by the slave cylinder. I don't even have a clue on how to fix the slave cylinder. So I guess I'll be pulling the whole thing apart soon. Thanks for the help and any tips on this cylinder will be appreciated. Jason |
09-01-2015, 08:08 PM | #18 |
Hone your wheel cyl, its cheap and easy you can even do it on the car .. Replace the cups if they are bad.
09-01-2015, 08:32 PM | #19 |
Noticed that C&G Ford sells a US version and I assume china version. Anybody have bad luck with the Chinese version? I've heard bad things about the bearings but can a cylinder be that badly made?
@Superreal says it's best to just replace it instead of trying to rebuild it. Anybody else have thoughts about it? Jason |
09-01-2015, 09:57 PM | #20 |
The Chinese wheel cylinder problem has been discussed on this forum, do a search and read what Richard at the Early Ford V8 Garage says about how to test them.
