Old 05-10-2010, 11:29 PM   #1
Trelpdx
Trelpdx's Avatar
Default 35 Valves and Guides
Guys,
8 years ago I bought the straight stem valves for my flathead. The valves have 2 grooves in the ends. Dumb question, but the keepers only can go in one of the two grooves. Which one?
Also, the just purchased the valve guide O-Ring for the intakes. These are like a sqare O-Ring about 1" in diameter. Where are these supposed to go?
Thanks much,
Peder
Trelpdx is offline   Reply With Quote
Old 05-10-2010, 11:50 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 35 Valves and Guides
Im thinking the keeper will go in the groove closest to the valve head. The rubber o rings go in the groove around the intake valve guides. They seal the guide to the block.
Old 05-10-2010, 11:53 PM   #3
Russ/40
Russ/40's Avatar
Use the top groove. Spring pressures are low in flatheads, and can tolerate significantly higher pressures. The o-rings to which you refer go into the slots in the valve guides, intake only.
Old 05-11-2010, 12:30 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Ken, I'm not sure which type lifter you are planning to use, but I recall reading a post some time ago that mentioned you should not use the lifters originally used with mushroom type valves if you are converting to the later type straight stem valves. I think the logic was when using the later straight stem valves with the early style lifters, there would be too much force/pressure concentrated in a smaller area on top of the lifter and either cause more rapid wear at the contact point or possibly the stem could break through the top of the lifter. I just thought about this as I read your original post and wondered which type lifter you are planning to use? JM
John
Old 05-11-2010, 12:48 AM   #5
Trelpdx
Trelpdx's Avatar
I'm using new adjustable lifters with straight valves. Thanks guys for the info. Starting reassembly tomorrow.
Peder
Old 05-11-2010, 07:01 AM   #6
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
By using the second groove (closest to the valve head) you will have higher seat pressure and less tendency to have any valve float. I would use this position if it were me.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 05-11-2010, 11:51 AM   #7
Karl Wolf
Karl Wolf's Avatar
You are using Chev valves. The position farthest from the head is the correct one for the keepers, the other is for the valve stem seal for the chev engine, totally useless for the flathead... Check this by assembling with out the spring and measuring the spring installed height... I like about 45 lb. spring pressure when valve is closed... Karl
Karl Wolf is offline   Reply With Quote
