08-13-2011, 10:57 PM | #1 |
e break cross shaft grease fitting
who is replacing with what ?
before i put the splash shields back on, maybe i should replace the two grease fittings on the frame. i did a search on this topic to no avail. proper way to remove, can i just tap for a small fitting or resize the hole and tap for larger ? maybe there is a catalog kit. |
08-14-2011, 08:47 AM | #2 |
Re: e break cross shaft grease fitting
The fittings are a press fit, hex sided (if original), if this is on a 28-30 e brake . I usually put a wrench on the fitting get it to turn some and pop it off, a little help with a screwdriver can help. Brattons sells them under grease fittings in the catalog.
08-14-2011, 12:10 PM | #3 |
i'll give it a turn . i will be replacing these with a modern . i do see the originals listed in the catalogs . |
