Old 06-09-2023, 06:12 AM   #1
Ray64
Ray64's Avatar
Default Vac. Motor
My wiper motor needs some kind of lube. Its getting lazy. How do i lube it an what with? Thanks RAY
Ray64 is offline   Reply With Quote
Old 06-09-2023, 08:34 AM   #2
mcgarrett
Default Re: Vac. Motor
Remove the vacuum supply hose nearest to the wiper motor and introduce about an ounce or so of Marvel Mystery Oil directly into the vacuum port going into the motor. Operate the mechanism by hand and you should notice things start to free up. Re-attach the hose and operate the motor with its vacuum source. That should help get you going again.
Old 06-09-2023, 08:56 AM   #3
Gary WA
Gary WA's Avatar
3 in 1 oil.
www.whidbeymodelaclub.com
Old 06-09-2023, 09:39 AM   #4
rotorwrench
rotorwrench's Avatar
MAFCA mentions light machine oil in this link. 3 in 1 is a light oil. Sewing machine oil is another that works well. Just remember that whatever goes in there will end up in the engine.
https://www.mafca.com/downloads/Tech...um%20Wiper.pdf
Old 06-09-2023, 12:57 PM   #5
Ray64
Ray64's Avatar
Thanks gotter goin again 3 n 1 oil RAY
