05-04-2023, 02:34 PM | #1 |
rear brake drum with outty or inny?
I just received a few old brake drums and my 1930 has a recessed inny ring around the neck, used for removing the drum. But one of the drums I just received has an outty.... a raised shoulder around the neck in the same spot as my 1930. Is this an older drum, like a 1928? I have never seen one of these. Thanks
05-04-2023, 02:43 PM | #2 |
Re: rear brake drum with outty or inny?
1928-29 have outer ring
1930-31 have the recess They are interchangeable |
05-04-2023, 05:42 PM | #3 |
05-04-2023, 07:42 PM | #4 |
Agreed. I've just made a batch of universal pullers that will work on either. Most cars here are 1928 or 9 so the early hubs are quite common. On that basis, I decided to make the pullers universal.
05-05-2023, 05:06 AM | #5 |
The puller made by Mitchell is universal, and the best puller I have used.
https://www.snydersantiqueauto.com/p...6169&cat=41753
05-05-2023, 07:38 PM | #6 | |
05-06-2023, 10:54 AM | #7 |
From the SB
05-06-2023, 08:15 PM | #8 |
Right at the end of that page, it says that the early hubs should not be used with the later wheels and vice versa. I have been using later wheels with an early hub for years. Is the world about to end?
05-07-2023, 01:37 AM | #9 |
The early hub mentioned is the hub with no emergency brake not what you are using.
John in partly cloudy rain showers Suffolk County England |
05-07-2023, 03:00 AM | #10 |
It is referring to the early 28 hubs and wheels which are the narrow ones. The mid28 to 31 hubs interchange and will accept the wider hubbed wheels from either mid 28 to 29, or the 30-31 wheels.
05-07-2023, 10:43 AM | #11 |
From SB
05-07-2023, 05:59 PM | #12 |
OK, Mine are the old hubs but fitted with new Cast Iron drums. My bad.
