Old 01-11-2023, 05:19 PM   #1
Bob's 1950 truck
Default How to stop the tailgate from rattling?
My 1950 f1 tailgate rattles like crazy. Do I have to cut and weld the large top links to tighten it up? Bob
Bob's 1950 truck is offline   Reply With Quote
Old 01-11-2023, 08:14 PM   #2
52flthed
Default Re: How to stop the tailgate from rattling?
Can you provide some pictures of your tailgate?
52flthed is offline   Reply With Quote
Old 01-12-2023, 01:31 AM   #3
GB SISSON
GB SISSON's Avatar
For the bottom hinge I have made bushings from poly tubing and for the rattling chains I use a piece of bicycle inner tube. While I have not done it, the big link you mentioned can be shortened to put tension to the bed sides. Haven't owned an early 50's PU for a while. I am assuming they used the same type hardware as the jailbars.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 01-12-2023, 08:59 AM   #4
FortyNiner
FortyNiner's Avatar
Pictures would absolutely help. My stock '49 behaves nicely - sleeving the chains eliminates any rattling from them.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 01-12-2023, 01:14 PM   #5
Bob's 1950 truck
Having a hard time trying to upload a photo. will try this evening
Old 01-12-2023, 01:26 PM   #6
flat 39
flat 39's Avatar
I used some peal n stick foam rubber window insulation from the hardware store and shoved it in the bed channel.
flat 39 is offline   Reply With Quote
Old 01-12-2023, 01:31 PM   #7
50fordcoupeman
50fordcoupeman's Avatar
I also used bicycle inner tube when I had my 'ol pickup. I didnt want the chains rattling and mostly rubbing the new paint. My tailgate did not rattle.
50fordcoupeman is offline   Reply With Quote
Old 01-12-2023, 01:50 PM   #8
deuce5wndw
deuce5wndw's Avatar
There are rubber bumpers for the tailgate channel. Carpenter has them.
deuce5wndw is offline   Reply With Quote
Old 01-12-2023, 03:02 PM   #9
CA Victoria
CA Victoria's Avatar
My wife rides in back, her legs are long enough to reach the tailgate.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-12-2023, 08:19 PM   #10
Lanny
Lanny's Avatar
Pictures Please
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 01-13-2023, 09:25 AM   #11
rottenron36
rottenron36's Avatar
I used large clear shrink to fit around the chain hook, and the tailgate mount on my 36 pickup. Tightened up everything and looks good. Ron
rottenron36 is offline   Reply With Quote
Old 01-13-2023, 12:55 PM   #12
Grassman
I just turn the Radio up.
Grassman is offline   Reply With Quote
Old 01-13-2023, 03:51 PM   #13
OldGold360
Ha. The tailgate would have to rattle pretty bad for my wife to get back there.
OldGold360 is offline   Reply With Quote
Old 01-14-2023, 03:00 PM   #14
Ross F-1
Ross F-1's Avatar
Got a link? I see nothing in their online catalog like that, and haven't ever heard of them.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 01-14-2023, 04:08 PM   #15
Krylon32
My deuce pickup made so dam noise inside the tailgate rattling was no problem
Krylon32 is offline   Reply With Quote
Old 01-14-2023, 07:01 PM   #16
deuce5wndw
deuce5wndw's Avatar
https://www.dennis-carpenter.com/pro...BAAA-8340725-A
Try this link, I know it says 53-72 but I don't know why they would work on the earlier trucks. It sure tightened up the tailgate on my 54!
Old 01-15-2023, 05:01 PM   #17
Bob's 1950 truck
Thanks for all the ideas. I'm going to shorten the big top links to tighten it up. If it still bothers me, add some sort of rubber bumpers.
Old 01-15-2023, 09:05 PM   #18
Ray in La Mesa
The tailgate on my beater '28 roadster pickup doesn't rattle but I kinda like the paint scratch patterns the chains make on the post sockets.
Ray in La Mesa is offline   Reply With Quote
