02-17-2012, 01:37 PM | #1 |
Wanted points
City:
duncan bc
State:
canada
Wanted , nos ford points & condenser , 4 cylinder model B . two sets would be better [email protected] thanks john
02-17-2012, 02:03 PM | #2 |
Re: Wanted points
I have those 22.00 a set point and condensor n.o.s. plus shipping.
02-17-2012, 09:26 PM | #3 |
Re: Wanted points
barnfind08 i sent you a pm
02-19-2012, 06:14 PM | #4 |
Re: Wanted points
Unless you are going to show the car there is a good work around for the condenser. Get a high quality Model A condenser. Elongate the hole on the tab at the end of the Model A condenser so when you slip the condenser into the Model B distributor you can screw it down. Take a short wire and run it from the end of the condenser to where the wire from the Model B condenser attaches. I believe there is a standard Model A wire that is the right length (about 3 inches). PM me if my explaination is not clear. Charlie Stephens Last edited by Charlie Stephens; 03-04-2012 at 12:31 PM. |
